Goodyear Tire pressure at track C2S
I have searched and have not found a direct answer to this: what pressure are you running on the track(going this afternoon for first time if weather cooperates) with Goodyear tires on 2020 C2S? Thanks.
I found the Goodyears to remarkable capable at the track, better than I thought for the OEM tires, the best grip for my sessions wad to keep the pressures at or below 35psi (hot)
Here's a lap at Thunderhill (Porsche Track App - ignore spped, the app will not export in mph) - run on the Goodyears:
smiles11 (03-30-2021)
Leecw (03-30-2021)
Did you see what the hot PSI was? I have not changed tire pressure since I picked up my C2S from the dealer, and I am seeing 44/50 hot on canyon runs. No traction issues, but I am not on the limits in a canyon either. Regardless, I was surprised to see the PSI that high on a higher speed but not particularly hairy run today.
Received 5,413 Likes
Run something like 32/36 cold. You really don't want to see anything over 40 hot.
You'll see a more comfortable ride around town and better bite in the canyon.
The following 4 users liked this post by LexVan:
