Is there a way to determine the exact day/date that your 992 was built other than TYD? Thanks
SA can give you screenshot of dealer tracking with the planned, expected, and actual dates for each event - including entry to body shop and production complete.
Also when you get your certificate it will have a build date. Whether that is first date it went in or when it was ready for transport to Emden is unclear (usually 5-7 days difference) but is there a reason you want to know the exact build date?
No not really, it is just that TYD keeps changing both the completion date and arrival date, first it said completion 2/5/21 then next day it said completion 2/3/21, so I just wondered. No biggie, thanks.
That date can and will often times change. If there is a delay in a part or if your car needs to be pulled aside for some repair. When it is completed, you will know the final date.
@Motorin Mark My experience with TYD was. that it was broadly inaccurate prospectively but very active after the fact and with each milestone it jumped around before the event but once the milestone was complete it seemed very accurate
Okay, I should be on track for March delivery then, thanks.
