Innodrive “not available” message
Old Jan 31, 2021 | 05:33 PM
peterdouglas's Avatar
peterdouglas
Default Innodrive “not available” message
I have intermittently received messages in my ‘21 992TTS to the effect:
”Porsche Innodrive not available - temporary condition”
have others had a similar experience, found a cause, or found a fix?
Old Jan 31, 2021 | 05:55 PM
markchristenson's Avatar
markchristenson
I had that message appear repeatedly and ended up turning off PID. Haven’t taken the car in yet to have to fixed.
Old Feb 4, 2021 | 10:51 AM
Chip Hawkins's Avatar
Chip Hawkins
2nd Gear
Picked mine up a couple of weeks ago and with PID enabled I always get that message. Going to bring it in Friday to have it looked at.
Old Feb 4, 2021 | 10:17 PM
mh992's Avatar
mh992
5th Gear
Look for innodrive in your assistance systems settings. There’s a speed limit setting that you may need to increase. Mine was default set to 20, and innodrive started working when I turned it up to max.
Old Feb 5, 2021 | 10:32 AM
peterdouglas
Exactly right - appears that P.I.D. gives the error message if its “maximum speed” setting is lower than the current speed. (Footnote - before discovering this solution, the service department at my dealer said that the problem was no/poor GPS signal!)
Here is the relevant section from the Owner’s Manual (page 213):
Old Feb 5, 2021 | 11:22 AM
Chip Hawkins
2nd Gear
I checked and my speed was set to 20mph. I put it to max and it did indeed work! Unfortunately, I tried again 20 minutes later and received the same error message. I verified that speed was still set to 130mph It was raining, but from what I have read it looks like that should not be a problem. I'll keep playing with it and see if it keeps refusing to enable.
Old Feb 6, 2021 | 10:00 AM
peterdouglas
i set to local unrestricted speeds (50/55) and so far seems to be working ok.
Old Feb 6, 2021 | 11:20 AM
markchristenson
This seems to have worked for me—thanks!
Old Feb 21, 2021 | 07:25 AM
peterdouglas
Again getting “Innodrive unavailable-temporary condition” message - for no apparent reason.
Any ideas of cause/cure? (Had previously changed the speed setting, so that’s not the reason anymore.)
Old Feb 21, 2021 | 05:16 PM
peterdouglas
Default "maximum" speed reset itself to 20 mph
While I had previously reset the maximum speed, it magically reset itself to 20mph, disabling Innodrive. Somewhat annoying.
Old Apr 9, 2021 | 04:16 PM
coastal's Avatar
coastal
Does ALK work (keeping you always in middle of lane instead of bowling alley bumpers), when Innodrive is disabled?
Old Apr 9, 2021 | 04:26 PM
siberian's Avatar
siberian
If you have Sport Chrono with the new "WET" mode that might be limiting the speed as well.
siberian
Old Apr 9, 2021 | 04:45 PM
peterdouglas
yes, if ALK is enabled.
mist frequent problem causing Innodrive to be unavailable is low speed setting in Innodrive settings
Old Apr 9, 2021 | 04:46 PM
peterdouglas
siberian
not the case in my own personal experience - rather the problem generally is caused by Innodrive speed setting sometimes spontaneously defaulting to 20mph
Old Apr 9, 2021 | 09:41 PM
coastal's Avatar
coastal
Ok would you recommend buying the innodrive just to get ALK...so buy it but disable innodrive and the result is adaptive cruise with keeping car in middle of lane, no bouncing. ??
I have a 500 mile drive home from dealer when I pickup my car in July so just curious if I should consider it. Right now I have just acc and lca, build locks next week.
thank you in advance.
