PCM - Favorite Home configuration ? Pics Please
#31
In the center top of home screen there are three bars and down arrow. This opens a drop down menu with home screen management functions. From there you can select functions for home screen listed on right then drag and drop. Once you get the weather widget on home screen click the widget while still in home screen editor to see the display options.
Oddly enough, once you add the Navigation tile and selected weather conditions are displayed on the Home Screen, tapping it takes you to Weather App (full widescreen) , NOT Navigation.
Bluehighways (01-24-2021)
#32
- Do not put the Apps / Weather tile on your PCM home screen
- Instead put the small Navigation tile on your home screen, then scroll to the right once so it gets set to Favorites
- Add your home address as a favorite in your Navigation settings
For step-by-step instructions, see: https://www.macanforum.com/threads/m...7/post-2582883
Wilsontour (01-24-2021)
#34
Received 2,674 Likes
Thanks to a number of folks in theis thread, I became aware of and have employed several of the options that are available. I have come up with this.
emesso (01-24-2021)
#36
#37
UPDATE: In sort, the small CP icon at the top of the Home screen perished. It seems that it will reappear "IF" CarPlay is been selected from the icon on the side stip of icons -or- "IF" CarPlay is one of the Widgets on the Hone Screen. Otherwise, left to sit overnight the small CP icon at the top of the Home screen will not reappear on its own.
Last edited by Bluehighways; 01-27-2021 at 07:40 PM. Reason: Long term "Learning" update.
emesso (01-25-2021)
