Aftermarket suspension/lowering options?
I have a TTS cab arriving later this winter and after considering it’s a cab (not a track car), my back problems, terrible local roads, and highway daily driving, I did not check the SPASM box. Actually, I checked it, then unchecked it, the checked it, and unchecked it until eventually the build locked
That said, from an aesthetics standpoint, I much prefer the 10mm lowered stance.
Could anyone recommend a very high quality aftermarket solution that would get me the same -10mm lowered stance without sacrificing any ride comfort? Maybe Ohlins R&T?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
Bilstein makes an aftermarket suspension for the 992 that works with the stock PASM controller. They also are the OEM supplier for the stock setup. Also have a setup that works with FAL. Not cheap but is a proper replacement that should eliminate the issues with lowering your car with aftermarket springs.
