911 992 entry and drive option
Old Dec 4, 2020 | 03:26 PM
Speed King998877's Avatar
Speed King998877
Default 911 992 entry and drive option
Has anybody got tge porsche entry and drive option.
mine doesn't seem to work is there anything you need to turn on in the settings on the computer
has anybody else suffered any problems dorsnt work at all
Old Dec 4, 2020 | 06:00 PM
aggie57's Avatar
aggie57
It's standard on all 2021 992, most 2020 cars have it. Search for 'Comfort Access'.
Old Dec 5, 2020 | 05:24 AM
mdrobc1213's Avatar
mdrobc1213
Yeah car recognizes me as I approach...doors unlock as long as I have the key on me and I just get in and turn the fob. Different thing on the 992 vs 991 was you could take the comfort access fob out of the ignition and use the key if you wanted...my SA said that is no longer the case with the 992 and Comfort access is permanently installed. Otherwise it works pretty seamlessly. Enjoy it.
Old Dec 5, 2020 | 11:59 AM
gcurnew's Avatar
gcurnew
On 2020s there's a toggle in a PCM menu to turn on/off Comfort Access. On my car the system is so flakey I'm at the point I'd ready to turn it off permanently, but my wife likes it. I think the difference in tolerance level for Comfort Acess flakiness is that with it off I just reach in my pocket to use the key while she has to locate and dig out the key from her purse.
Old Dec 5, 2020 | 03:54 PM
aggie57's Avatar
aggie57
That's definitely an advance on the MY20 cars, we have to touch the underside of the door handle to unlock it, like on a Mercedes for example. It works most times first go for me.
Old Dec 11, 2020 | 08:47 PM
vlastan3's Avatar
vlastan3
I was reading it can unlock your car as you approach it. But can’t make it work that way
Old Dec 11, 2020 | 09:22 PM
FrankAT's Avatar
FrankAT
The comfort access feature seems to have mixed results for people. I've now owned two 992's and on both the feature works only about 30% of the time. I finally decided that the security risk outweighs the intermittent benefit and disabled it in PCM. One thing to know is that the key has a motion sensor and goes into a sleep mode if motion is not detected for a certain period of time as a security mechanism.
Old Dec 11, 2020 | 10:14 PM
vlastan3's Avatar
vlastan3
mine works 95% of the time. It all depends where your key is in your pocket and how far from your car you stand when you approach the door handle. Normally in the pocket of your trousers when you go cyclise to the door handle it works well. I do like how the bonnet opens with a wave and the fact that you don’t need to put a key in the ignition to start the engine.
Old Dec 11, 2020 | 10:22 PM
aggie57's Avatar
aggie57
In a 992 you cannot remove the key from the ignition. It's a fixed item, all 992's have that.
Old Dec 11, 2020 | 10:28 PM
vlastan3's Avatar
vlastan3
i assumed it was an option for comfort access only. So interesting to know. So the key fob only unlocked the door and then you start the engine which is cool. That wasn’t the case in the 911.2 I had before
Old Dec 11, 2020 | 10:32 PM
aggie57's Avatar
aggie57
Yep, it's still a lever you need to twist though. Not a button like in most cars.
Old Dec 13, 2020 | 03:22 PM
Speed King998877
Default Entry Drive
Booked into the dealers and looked like a faulty door sensor in the door dealer no replacing the door handle which includes the sensor apparently
Old Dec 13, 2020 | 08:07 PM
vlastan3's Avatar
vlastan3
my comfort access does not recognise me when I approach the car. It just reacts when I put my hand in the door handle. Could there be an issue with my car?
Old Dec 14, 2020 | 02:07 AM
mikey94025's Avatar
mikey94025
My MY20 992 with Comfort Access doesn't unlock automatically as I approach, i.e., I have to first put my hand under the door handle to initiate the unlock (and it still fails to unlock some percentage of the time). A few 992 owners have reported that their door handles pop out automatically as they approach, but I think this is not how Comfort Access works for most of us. Right?
Old Dec 14, 2020 | 02:12 AM
aggie57's Avatar
aggie57
right. My 2020 has never unlocked as I approach, always need to place my hand under the handle.
