Configurator - how do I know I got eDiff and PTV
I am looking in the configurator and I have a hard time seeing where eDiff and PTV+ is added.
my understanding is for the base, can’t get eDiff nor PTV
for the S - what option do I need in order to get eDiff and PTV+
thank you
thank you
Received 5,402 Likes
PTV was standard on the S.
Opps.....thought this was in the 991 Forum.
I see it now, listed under Standard Equipment for the S. Not listed for the Base model and not available to add.
Thank you
Thank you
Received 2,647 Likes
Per the Porsche Carrera Brochure: "Porsche Torque Vectoring Plus (PTV+).Available on Carrera 4 and standard on Carrera S models with Porsche Doppelkupplung (PDK),." and "The rear differential lock is equipped with electronic
control, oering a fully variable torque distribution."
You have to select a Base Carrera 4 for the configuration system to offer PTV. It's a $1,500 option that comes with the brake system functions as well as the electronic differential.
If you try and configure a 2WD Base Carrera, the option isn't listed because it's not available.
If you try and configure any Carrera S the option isn't listed because it's standard on all Carrera S models.
dashanin (12-01-2020)
Thanks. I was trying to see if eDiff and PTV was option on base. Friend is considering a base but would take it to track.
based on my learnings here I will advise him to consider a 992S or used T. Big price difference but he runs a Audi/VW shop here and does APR tunes all the time. So he can build out a T very nicely.
