Manual Transmission Question
With the manual transmission, I understand the auto rev match on downshift is not active when in normal mode, but is active by default in sport and sport plus. Can this be disabled in sport or sport plus? I have read conflicting reports. While there seems to be no direct way to disengage the auto rev match in sport/sport plus, some seem to suggest that auto rev match disengages in these drive modes if you turn off the stability management. Any insight would be appreciated. Thanks in advance.
Received 5,388 Likes
On the 991 you could disengage PSM, and knock out rev-matching. Can you do this on the 992, too??
You cannot disable rev match in sport or sport+ - it is only disabled by default in normal mode.
Would be nice to have the option, but alas, you cannot.
Thanks for the response. Just to confirm, auto rev match stays engaged even when you disable PSM in sport/sport+? Sounds like it didn’t work that way in the 991 generation based on LexVan’s post above. I understand there is no way to directly disengage rev match in these modes, but was wondering whether it disengages when PSM is off like it did in the 991 generation. Thx again.
I typically drive in sport mode, and PSM is disabled in that mode, and rev match is enabled. So my assumption in Sports+ with PCM disabled, the same result.
No it doesn't disable rev match - I will try it again, but I have fiddle with the PSM being off, and pretty sure it still rev matched. Will need to double confirm that, but I do not think it disables the rev match.
Thanks Richard. Appreciate the quick response. Will be interested to see what you learn on this. For what it’s worth, I don’t think PSM is disabled automatically in sport or sport+. Rather, it has to be manually disabled in those modes as well (the limits may be higher before PSM engages in those modes, but I believe PSM is on in all modes unless manually disengaged.). Thx again.
I will take it for a drive and try it to confirm.
Received 2,688 Likes
I'll check too. There are three PSM modes, normal PSM which is on when you are in 'normal' mode, PSM Sport which you select by pressing the PSM button briefly, and PSM off which you select by holding the PSM button down for 2 seconds. According to the manual PSM off is only available on cars with Sports Chrono which all manual cars have.
So went to get some milk.
- PSM remains fully active in both Sport and Sport+ modes, is only changed via press of the button.
- In PSM Sport (i.e. short press of button) rev match is on / enabled.
- With PSM off ( (i.e. long press of button) rev match is off / disabled.
aggie57 (11-18-2020)
Any idea if it can be disabled in individual mode? Would like to drive with sport plus mode but turn off rev matching.
