Dumb acceleration question...
Would using the FAL system to raise the front of the car transfer enough weight to the back end to lower 0-60 times at all? I know it couldn't possibly make a big difference, but I'm just wondering if it would have any measurable effect whatsoever. I'm not sure why this popped into my head, but I'm just curious what others think of the idea.
Like I sait, it's a dumb question. In my mind, I picture the car rocking back under acceleration anyway, so I thought lifting the front end would get it tipped back ahead of time and maybe give you better acceleration.
I don’t think it’s a dumb question, FWIW. We just shootin’ the breeze ‘bout car physics!
The theory is correct. In practice the front end has to lift quite a bit to transfer the weight on acceleration. When drag racing we would disengage the front anti roll bar and install 90/10 shocks on the front to get the front end to lift putting more weight on the rear tires. It really only helps when you are traction limited. In drag racing, classes limit the tire size so weight transfer gives you the most traction for a specific tire. On a 992, if you are traction limited, get a bigger rear tire as in GT2...
aggie57 (09-04-2020)
