My Solution to Front Lic Plate Holder
I thought a lot about the front license plate and rather than take a chance of a cop with a bad attitude and a fine here is what I came up with. I cut the plate to size so to miss the parking lot sensor and the ACC sensor and used plexiglas glass, same size, backing to give the plate some rigidity. Then used a 1 inch long 1/4X20 bolt, a 1/4X20 coupler, a 1/4X20 all thread long enough to go through the corrugated black plastic at the back of the pocket ( you can always put a rubber plug to cover the hole and none would see it). To hold the all thread mount in place I used a 1/4X20 nylock nut, a fender washer, (Porsche black plastic), fender washer and lastly a 1/4X20 nylock nut to hold it tight. Use blue lock tight where needed.
If you look at the very southern tip of Texas you can see the bolt. It works for me.
Creative... Now you just need to mass produce it and sell to all the 992 owners that need a better front license plate solution (that works with their front camera and parking sensors). :-)
Seeing the smaller plate made think it's too bad that you can't spec a motorcycle plate, at least for the front tag.
