Porsche ID disconnect
Has anyone had issues w/PCM not retaining the Porsche ID? Mine works for 1-2 days max before needing to be reentered. Tried all the retention options with no luck, even reset the PCM and reconnected to the iPhone. TIA!
yes. it's been the subject of a few threads here. i had the exact same issue for the first month or so of ownership. i also know a bunch of other folks have shared similar stories. seems there is no one size fits all solution. i actually ended up deleting my entire driver profile, started over from scratch, then added my porsche connect ID and set it to connect to my newly set up driver profile and it's been reliable ever since. could be a coincidence, so your mileage may vary. good luck.
Received 2,903 Likes
Same here, had the car a little over 1 week and it seems prone to loosing the connection. Not seeing much benefit in having that set up though, Porsche Connect and memory settings still seem to be there.
Sometimes, launching the Connect app on iPhone will resolve that issue.
Same Problem here. 2 to 4 days max, then it will drop out. Took it to the dealer to have it fixed along with my seat back and the apple car play. They had the car for 5 days, and that seemed to fix it for a few weeks, then it started back dropping out every few days or so. I’ve just given up with it.
