Rear wheel steering - battery replacement
There are three airports where I live, and if I go to the closest one, then yes, I take Uber/Lyft. But the other two, depending on the hour of the day, can take 1-2 hours...then I prefer to drive myself. If its not bad traffic, then I actually enjoy driving myself. Once, in bad weather, it took me 3 hours driving home from the one furthest from my house.
Oh, to be concerned about airports again.
Plus, I would never feel comfortable leaving my car at the airport for days, much less weeks or even months.
Well, if you are parking your car at the airport for weeks on end (or even more than a month), I would imagine the airport parking would be more expensive than even a 1-2 hour Uber/Lyft ride.
The airport is about an hour away from the house. While I have tried taking Turo/Lyft from home to the airport on a few occasions, I strongly prefer driving myself. Stepping off of a red eye and waiting for a ride share home sucks. With your own car, you just hop in and go. Plus, it's always great to get a fresh reminder of how fast our cars actually are on the ride home, especially after spending the week in a rental car. LOL
detansinn (07-20-2020)
So, on Friday I contacted the Porsche dealership regarding the Li battery, and how best to “jump start” the battery should it become depleted enough that I cant start the car? Here is what he told me (I do not know if this is accurate, but this is what he told me....keep in mind, he’s trying to sell me the rear wheel steering option, so I don’t have any reason to think he would lie about this):
”Don't think you can jump the Li Ion battery, it's just got to be recovered, I believe it's a longer process that probably should be done by the dealer.”
If that us true, then I am cancelling this option, as I don’t need another complication...and given the few times I plan to track this car, I doubt I will be pressing the car hard enough to benefit from the 1.5 degree turn from the rear wheels. For some, I understand the performance benefit, but for me, if it comes with the disclaimer (so to speak) that you can;t jump start the car....then the negative outweighs the positive.
I had a 2013 911S w/o RAS and a 2019 Touring with RAS and drove the heck out of both. I could NOT ever tell the difference between the two as far as RAS is concerned but for "serious" turn-in-anticipation on a track. What I mean by that: your mind's eye has an anticipated turn in and achievable radius based on expereience with the track and car for each turn - with RAS, and quite magically, in the turn it gets even tighter as you almost imperceptibly feel the back come around and tighten things up even more. It always freaked me out a little as I thought maybe I was breaking loose but I know it allowed me to brake a little later and hit the gas sooner, hustling around the track at top speed. You just learn to have faith in the car and RAS. If that was important to me, I would order RAS. Otherwise, I would not.
And, on my 992, I did not.
Thanks. That sort of confirms what Nick Murray said about rear wheel steering. He had a funny comment in one of his YouTube VLOG’s, where he said he was at a Porsche track event with several other “longtime Porsche owners”. he said they were testing out 911’s that they were told all had rear wheel steering. After the event they all gathered and he said everyone was “praising the benefits” of rear wheel steering. Afterwards, he privately went up to the Porsche rep and said that he was sure these cars did not have rear wheel steering...to which the Porsche rep said, he was right, and that Porsche had sent them the wrong cars without that option. The moral of the story: If you think something will help your driving skills, even if it isn’t, and like a placebo, you will believe it’s helping you. People believe what they want to believe. For some, it may help...but I suspect only for those that are truly pushing the limits of what the car will do?
Vintage72 (07-20-2020)
Truly, you will never know the difference unless you are a bit of a track rat, and even then, minor but beneficial to be sure. People always say stuff like, it "transforms the car" or "it makes the car feel smaller" or some similar BS. Its BS. 911s are small, agile, amazing cars with or without RAS. Its a cool option to be sure, especially if you are going with the "sporty" ethos of the Sport Package (SPASM, exhaust, Chrono, etc.), plus aero or carbon roof, or other go fast feely things.
Yes, they do make lithium jump starters.... There are quite a few.
https://www.walmart.com/ip/NOCO-Boos...ll&athena=true
Skip PDCC & RAS
Yes, I know there are many Lithium jump starter batteries. These jump starter batteries are lithium batteries (to reduce weight and size). I recently bought a NOCO GB150, which is advertised as an “ultra-safe jump starter Li battery”. What they mean is - their battery is Li. However, when you look at the manual that came with the jumper battery, on the 2nd page of the instruction is says, “to be used ONLY on lead-based or NiMetalHydride batteries...use on other battery chemistries could present a serious fire hazard”. That’s their warning, not mine.
Furthermore, I got the following from my dealership:
”Spoke to the Tech, read the manual, you can jump start the car using the special posts, you just cant jump start the battery, complicated but the Li battery is isolated once it drops below a certain voltage. You can damage the battery if it is excessivly discharged but it should not be because it isolates itself.”
So, if I understand what he said correctly, once the Porsche Li battery is depleted below a certain level, a built in safety mechanism isolates the battery from the car’s electrical system, thus preventing any further drain to the battery, which ultimately, could destroy the battery. That’s all good. BUT, it sounds like once the battery is isolated/disconnected, that you may have to take it into the dealership to reactivate?? I do know that the people at Antigravity, who make lithium car batteries, tell you that their batteries have this feature, but that there is a button, or switch on the battery that you have to engage to re-connect the depleted battery to the car;’s electrical system. Bottom line - this is NOT as simple as with a traditional Nimetal hydride or lead based car batteries that we all grew up using. If you jump start the car, but the Lithium battery is not reconnected to the car’s electrical system, then you are running everything on the car from the alternator...
