Is it possible to drop the glove box?
Not sure if this will even help, but I'm trying to get behind this right panel in the pic. Unfortunately, the bottom clip on this trim piece (which snaps into the fuse box trim/cover) bent, so I needed to replace it. As you can tell, it's a very tricky spot to get this behind the panel correctly.
ryanlsmith (07-15-2020)
Yea, the door seal was definitely a factor. I realized I had to slide the trim piece up, though. You place it about half way - where the second clip is still below the edge, snap the top clip in first, then slide up the rest of the way while making sure the bottom two clips fall into the channel. I'm pretty sure I got it all back...
