Instrument cluster - customized view - help please.
OK, maybe i'm missing something. I am trying to customize the view on the instrument cluster and can't seem to figure this out. No problem getting to the customize screen in the PCM through Car/Control/Displays/Instrument Cluster Display/Content/Customize View. From there I can drag and drop the four items I want to display. BUT they do not show up in the instrument cluster? And I can't seem to access my customized view anywhere? I know this is a simple thing that I am missing. Can someone point me in the right direction here? Thanks in advance.
Are you talking the PCM or the information display?
When you are focused on the display on the right display, and have scrolled to the view with the default bar gauges layout, press in your roller **** and scroll down to "View" and click the roller **** to select that menu, then scroll down to "Customized" and select it.
deetz307 (06-14-2020)
