How to set up a CTEK charger 12v passenger footwell - 992
#31
I'm not sure why everyone is going through this convolution. Why not attach the charger to the battery posts directly? I know it's a pain removing the huge plastic shroud... but, I'm assuming you need to leave the window open to run the power connection, so whether it's that or the frunk being open (I just place a clean sheet to protect it from dust etc. what's the difference? I must be missing something obviously
siberian
siberian
- The Porsche owner manual says you should connect to the battery "+" and to the car mass for the "-". So some people prefer connecting viat the accessory outlet in the passenger footwell, which avoids removing the "plastic shroud".
- However, with LiFePO4 batteris, it is safe to connect directly to the battery"-" (official Porsche statement). So your suggestion is valid, just have to pass the cable through the "vents" in the plastic shroud.
- When connecting via the accessory outlet in the passenger footwell, you do not need to leave anything open. You just close the passenger door on/over the charger cable.
#32
Hola Joan, and thank you for your comment. In actual fact there is a decal on the battery that shows not to connect to the negative terminal - a good practice for any type of battery whether wet,, AGM or LiFeP04. I just didn't understand why folks were going through all this. Chau
siberian
siberian
#33
I have both chargers and tried both methods to charge using the 12V accessory outlet in the passenger footwell.
Please note that the CTEK "cigarette lighter" adapter for the charger (CONNECT - Cig Plug) has a label that says explicitely "DOES NOT WORK WITH CAN BUS".
And the CTEK document says (https://www.ctek.com/storage/C41611B...-low-UK-EN.pdf)
CONNECT– Cig PlugConnect – Cig Plug is an easy to fit adapter that allows charging from a CTEK compatible charger through the 12V cigarette lighter or accessory socket. 400mm cable length.
Compatible with all CTEK chargers up to 7A.
Connect – Cig Plug is a universal model that fits both 12 mm and 21 mm sockets.Part no. 56-263
Note: Socket must be powered even when ignition is in "off" position
- To charge successfully with the Porsche Charge-O-Mat Pro, you must lock the car.
- To charge successfully with the CTEK Lithium XS charger, you must not lock the car.
#34
Direct to battery and separate negative post is the way to go. Don’t worry about sequence or whether doors locked. There are plenty of areas where the wire will fit through the shroud/cover(plug too bulky, but pass wire before connecting). You never have to remove the shroud to plug in! There’s a separate connection for negative, away from the battery. DO use a cloth if wire might rub against your car (suggestion I got from McLaren dealer when I thought McLaren was the GOAT. Didn’t use on wife’s Macan and it has micro scratches).
coastal (04-25-2021)
#35
#36
Cut the eyelet to use on negative? @markjeansonne
There is a fixed bolt coming out of the vehicle that was larger than the eyelet.Didn't want to loosen the bolt fixed to the body of the Porsche; and didn't want to splice the wiring to my tender connector, so cut the eyelet and then it fit perfect.
#37
Also, have you tried to unscrew the bolt, place a non cut eyelet below and then screw the bolt back? This is possible on BMWs, apparently.
#38
How do you ensure a snug connection between the cut eyelet and the bolt? Did you use plyers to close the open eyelet over the bolt? IS the contact good (durably good)??
Anyway, the bolt you see is larger than the eyelet. Hard to see from the pic, but the bolt that screws down has a sleeve, and that sleeve has to press the eyelet down unto the fixed bolt. The eyelet wrapped around the bolt good and everything was screwed back tight. Let me know if you want detailed pics of the bolts unscrewed; or check it out on your 992.
#39
Difficult to explain, but you see one bolt in the pic. That screws into the fixed bolt (for lack of a better word). So I should have explained that a bolt screws back over a fixed bolt.
If I understand you correctly, the "bolt" has two parts:
- A "removable sleeve" with a hex ending at the top;
- A "fixed part" of the bolt.
Then you can reattach the "sleeve" over the "fixed" part of the bolt and screw tight to secure the eyelet.
markjeansonne (04-26-2021)
#40
This is how I put the 12v charger coming out of the Frunk.
I can see per the battery instructions Porsche does not recommend putting the negative on the negative terminal on the battery but rather than put it on the designated bolt, do you think its is possible to put it on this bolt (see the picture). It is the bolt that is bolted to the frame.
If you follow the cable, it connects back to the negative but that cable has what looks to be a fuse or regulator so it doesn't look like it would damage the battery. Thoughts?
#42
If so, doesn't it rattle in there. And did you feed it through a hole or make that hole for the cabling?
#43
3dpedal, yes coming out of frunk, near windshield, do NOT have to pop the frunk.
No rattle. Yes has cap for when disconnected and driving in weather. I fed the wire end through a small pre-existing hole,
see pics again.
see pics again.
3rdpedal (04-27-2021)
The following 2 users liked this post by peanuboy:
findtom (05-09-2021),
markjeansonne (04-27-2021)
#45
I have Porsche brand charge-o-Mat pro.
Here is my experience-
1. Plug into the footwell socket
2. Turn on the ignition accessories, without starting engine. Left it on for 1 min. or so and then do step 3
3. Plug the charge-o-mat pro to wall socket
4. Green light should be on
5. Select mode and choose li-ion (or car icon -Agm)
6. The charger will briefly cycle thru the battery charge level capacity. Wait for 1 min. or so and then do step 7
7. Turn off the ignition accessories.
8. Lock the car. (*)
(*) the very first time when I was doing it, I did NOT lock the car at all and after 30+ mins, the charger was shut off automatically as the light was blinking green.
Therefore, this was my own experience on how I got this maintainer working. I’m aware this thread has others said the unlocked of doors will also work as well, so do try both ways to see which one will ultimately work for you .
Steve 96C4S (12-09-2021)
