Tips and Tricks - Things you may not know on your 992
Sport and Sports + autostart is disabled
Normal it is not disabled, but you can through the PCM menu (or if you set up your individual settings).
This is the same on both the PDK and Manual.
On the manual transmission, even if autostart is disabled - if you were to stall - If you push in the clutch, it will autostart back up.
4.) Frunk opening - with key in your pocket. You have to do 2 swipes starting at the top of the porsche logo and down, then up, then down again and it will open 95% of the time. It is a little voodoo, but that is the most consistent way I have found, and I have done it (well a lot of times).
carson2 (05-01-2020)
Opening Frunk with out actuating key or interior lever.
i have 100% success with key in pocket or car, by swipping hand on the bumper just under Porsche badge starting about 5” from left to right. I do not touch the hood at all.
michael818 (10-24-2021)
I just tried this on my 2021 C2S, and it works as stated. Key in pocket, and i move my hand down and up over the badge. Neat trick, but not sure how useful it is in real life. I like the kicking motion of below the trunk in the old BMW's better, so if I am carrying bags with both hands, i can use this kicking motion to open the truck. With the Porsche, I still need to use my hands to open the Frunk, if its unlocked by the hand motion.
doug_999 (10-25-2021)
This thread that @gcurnew started was very helpful in understanding where the frunk sensor is located.
https://rennlist.com/forums/992/1236...-revealed.html
