Navigation at start
Are you saying if he never set up a driver profile and is just operating in "guest" mode, the current settings are not automatically saved to the key when the car is turned off? I'm not sure about that since my dealer set up my driver profile upon delivery. Otherwise, there is no additional saving routine required as far as I know.
I use my profile (not guest) which is the same of my ID Porsche. Perhaps it works in a strange way because I own more than one car with the same Id...
Go to the main instrument panel (above the shifter) go to car, settings, display. You can select what shows up in that screen - uncheck Nav (and anything else you do not want to be able to scroll on that part of the instrument selection. It will not show up anymore.
The problem is the nav appears every time I turn on the car. I would like to find the screen I have left when I turned off the car.
