PASM vs PASM Sport Suspension?
What is the different between PASM, which is standard on the 911, versus "PASM Sport Suspension", which is part of the Sport package or a $1,020 standalone option. I see under the PASM Sport Suspension details it lists the following::
- Electronically variable active damping system with two manually selectable modes: "Normal" and "Sport"
- Ride height lowered 10 mm compared to standard
- Stiffer anti-roll bars (front and rear)
- Extended front spoiler lip
- Increased maximum rear spoiler height
The 911 GTS Coupé models are equipped with the PASM sports suspension. The body sits 10 mm even lower. The springs are harder and shorter, and the anti-roll bars on the front and rear axles are stiffer. The front spoiler lip is larger, and the rear spoiler extends even further.
Assume the comment is around Sport PASM specifically and nothing to do with the fact that it's a GTS.
