Manual GTS?
Has there been any information regarding manual availability in the GTS, or will only the S be available as a manual for the entire line for the foreseeable future?
If the plan is to produce only one trim in manual, I guess it would make sense to choose the S as it has the broadest range of options and buyers.
Manual is a must so just wondering if I should wait or just go manual S
GTS will be offered with the 7-speed. There are pictures of the 992 GTS online and in the forums with a seven speed.
The Base Carrera 2/4 seem to be the only 992s excluded from the manual transmission party, but don't be surprised when a Carrera T lands with the Base engine and a manual as an option.
The GTS will have all options as its the more expensive model.
Only the "cheap" base carerra option will be punished by removing options. GTS is safe and will have all performance options.
No, they plan to punish/motivate those who only wanted to get the base 911. Just like the restricted RWS to only S models or higher with the 991.2.
These cars are so customizable according to your driving style and preferences, that's why there are 27 iterations of the same car, including all the GT variants.
The base 911 is great, but then when you get on it, you might wish the standard brakes were a little gripper, the car was a little lower and hey this RWS really makes the car pivot on its axis....and so on.
