991.2 Turbo vs 992: Technical Specs
911 Turbo specs were taken from the official Porsche specs. Of course, 0-100 has been measured as low as 2.7secs. Still not far away from the 992!
Technical specs sources:
Wow the weight difference is only 30kg but the hp diff is 90. Shorter gear ratios must make a hell of a difference.
What's with the *?
That post is kind of nonsense. An attempt to make the 992 better/close to a 991.2 Turbo when in fact it's not any faster than the 991.2 GTS. Seems like a bunch of cherry picked info.
