Interview from creators of the 992 with R&T
https://www.roadandtrack.com/car-sho...-specs-details
The "iconic" 911 has plans for a hybrid. More variants is not a good thing.
interesting thanks.
trying to like the new version, still struggling.
I don't understand the benefits of wet mode, it feels like something a lexus should have, not a porsche. The fact that they keep emphasizing this feature in every article about the 992, I find puzzling.
5 seconds faster around the ring is definitely pretty large- I am not sure how Porsche is saying this car is about .4 seconds faster to 60, with more weight and barely any more hp/torque. Right now the S is 3.1 seconds to 60, so the new one could be 2.7? Makes no sense to me, every .1 is exponentially harder especially when you get to the sub 3 second mark.
interesting thanks.
They knew the next generation would have to be heavier and not significantly more powerful -- remember that the 992 was already well into development the day the first 991.2s hit the road! -- so they sandbagged the 991.2 specifications accordingly.
Also, the bigger rear tires will help a bit. They will run with lower air pressure, resulting in a bigger contact patch.
They were lying about the 0-60 times of the previous generation. Every single magazine test found them to be quicker than specified, with a margin of error that was too large to be a margin of error.
As for the ring, that is explained by the 4cm wider track front and rear which makes the car more stable for Ring Times, but less fun to drive. Another reason I won’t be getting a 992 GT3. With the .2 RS engine and some basic weight loss tricks the .1 GT3 may have the same power to weight ratio as my .2 GT3, and achieve a modestly faster Ring time due to wider track, but it will feel heavier and less playful to drive.
Received 1,150 Likes
agree with everything you said. This explains the 0-60 times.
But GT3 already has the wider track since 991. Basically now 2wd Carreras are as wide as AWD and GT3 cars were all along, that's all. The new body is exactly the same 1852mm wide as AWD and GT3 bodies of the 991.2 generations with the same track. So not sure how widening of C2 and C2S versions to match AWD cars will make the next GT3 less fun - seems like unrelated things.
I could not find the exact track specifications for 992, but the 991 GT3, GTS and C4S track is the widest possible track in 1852mm body (1552mm) given the constant wheel width. Basically, the only way to increase the width of rear track would be to make tires skinnier, which we know did not happen. The front track is a different story, though, because in 991 generation only RS had wider front track. So 992 C2S is basically the 991 C4S rear track but front track is likely closer to that of the RS. That Depending on the set up, that could either means nothing or make for very slightly more playful rear end by shifting slightly more traction forward.
Are you aware that magazines quote 0-60 times with use a one foot roll-out while most manufacturers (except for Tesla) use a standing 0-60? That’s why you’ll commonly see a 0.3 second faster 0-60 time with magazines than with the manufacturer. It’s not a conspiracy my friend, just different ways of measuring 0-60 that the whole industry can’t seem to agree on. If Porsche is quoting 3.2 second 0-60, it will probably be 2.9 seconds with a one foot roll-out.
I still find it hard to fathom how 23 hp and 20 or so lb/ft of torque can make up .2 tenths seconds- when you look at the 991.2 gts vs s the times are really about .1 to 60 and 1/4 mile faster...
Yep! Many interesting facts and thoughts in there, this is just the last one I came across: "there's a small umbrella holder in the passenger-side door sill, which one of the 911's product planners tells me is a feature that was found on some early 911s."
Thnx for pointing out this article.
Why is Porsche forcing its customers of 992 to have the empty space for the electric drive train now. It is not like these models will go hybrid. Do this 992.2.
Thanks for the share. Excellent article - very disappointed with the designer on changing good things to bad.
so you are saying 2 tenths quicker to 60 vs the 3.1 of the c2s? that probably makes sense.
interesting thanks.
If so, you obviously seen how badly Florida drivers are in the rain.
The very first day I drove into Florida in a 993 I saw a damp highway and cars spun out into the highway median for several miles. It looked like the first day of snow in the North East.
Wet Mode must have been created with Florida in mind.
As far as faster times, I bet it is all about grip. Better tires and suspension, coupled with torque management puts the power where it does the most good.
