992 TTS Stage1/Stage2
#31
I believe the frame/housing is the same for the TT and TTS.
The TT most likely has smaller compressor/exhaust wheels, which could be upgraded within the housing.
ESMotors has modded factory turbos and put larger wheels in for their upgrade package.
#32
This could be true I am not sure TBH.
Regarding road course and tuned cars, I would really watch your logs and temps. The car isn't designed for all that extra power in regard to cooling & a constant beating around the track. I would run a moderate tune and not something that is on the edge of pulling timing. It would also be a good idea to mix half a tank of race gas in for extra protection.
#33
You never know. Strange lights on the dash. A/C refuses to work. Key not recognized. Fuel pump goes bad. The hardware is pretty reliable - not many blown engines or trannys. Its mostly components and electronics. I love them, and have a 750S Spider (my 7th Mac). Nothing goes like them. Top end pull is something else -even stock. Love my 992 TTS, but the Mclaren is a rocket.
luv2sleep (06-22-2024)
#34
#35
I've had 3 MC's and only had issues with one. Really, the ownership issue for me was the lack of dealers in my area. Services and warranty issues required an inclosed transport.
#36
That’s the bad deal here. Mac dealership is 3 hours away. A lot to like about the Mac. Carbon fiber Monocoque, etc. Awesome ride, just needs a dealership nearby. I still might break over some day.
Kinetic1 (06-04-2024)
#37
Only mechanical difference between the two.
https://rennlist.com/forums/992-turb...s-engines.html
Tuned...M-E says they get pretty much the same output at Stage 1/2...similar TQ and about 30 more HP from TTS.
Kinetic1 (06-13-2024)
