Spark Plugs
Spark Plugs
Anyone have info on spark plug life....I can't seem to find anywhere in the Manual what the time element is for replacing them - service dept tells me 30k miles
RD16RR (04-09-2024)
I just had mine replaced at 3 year mark...or near 40k km.
Was running smoothly before and after...with stage 2 for past 2 years...so almost 24k km.
Going forward, I will replace about every 15k with M-engineering gaped plugs.
RD16RR (04-10-2024)
Yea with mods, I will do mine every 2nd summer, good to have fresh plugs if you're pushing the boost and using different fuels.
Also, upstream, closed loop O2 sensors are a good thing to change out once and a while to make sure readings are perfect.
Cheers
Cheers
The following 2 users liked this post by Angryinch:
Pad Bender (04-10-2024),
RD16RR (04-10-2024)
