992 Turbo and Turbo S 2019-Current
OBD Killer
Old Jan 4, 2025 | 03:30 PM
pepinozaur's Avatar
pepinozaur
it works just fine - street and track. the only problem is it will drain your battery if left for too long in the obd. perhaps an obd extender would be nice for easier install/remove
if you have. a tune, this isn't needed, you can remove the codes by the tuned map
Speaking about tunes, I see some tuners here attacking it, I wish they took better care of my 720S engine a few years ago..
Old Jan 5, 2025 | 04:39 AM
7184RS's Avatar
7184RS
Thank you for the feedback
Tuning means warranty void which is a no go for me as these engines are not 10k Camry engines plus I'm planing to get Porsche Approved warranty
I have a Cobb fuse box which leaves the OBD connector visible so disconnecting the OBD is not a problem when the car is not moving for "long" periods
Old Jan 5, 2025 | 05:02 AM
zukbang's Avatar
zukbang
what's a Cobb fuse box???
Old Jan 5, 2025 | 05:04 AM
7184RS's Avatar
7184RS
This one
https://www.cobbtuning.com/products/...er-for-porsche
Old Jan 5, 2025 | 06:24 AM
HardBoost's Avatar
HardBoost
Originally Posted by Spatia
Has anyone used this product to deal with ECU errors before they become a nuisance from an Exhaust and Cat change? OBD Killer.
Here is a quick suggestion, purchase two of the below (one for each bank) and install it. You can run stock tune with cats deleted and no CEL. Use the smallest O-ring of the three that are included in the kit. You can do the install job on your garage floor.
Vibrant Performance J-Style Oxygen Sensor Fittings 11619
I've used this product for years on all my 911's, GTR's, AMG's, M-cars and so on and it has always worked!
Thanks!
Old Jan 5, 2025 | 06:41 AM
7184RS's Avatar
7184RS
Thanks!
This works well for lambdas, but sadly is useless for OPF pressure diferencial on EU cars
Old Jan 5, 2025 | 06:50 AM
HardBoost's Avatar
HardBoost
I am located in the U.S.A. and it has always worked for me/my cars. If you like, perhaps you can contact the manufacturer to see if they make such units for OPF EU models.
Old Jan 5, 2025 | 12:18 PM
zukbang's Avatar
zukbang
so you would have to use OBE extender for this, right?
Old Jan 5, 2025 | 12:21 PM
7184RS's Avatar
7184RS
And extender ? What for ? You already have the hole for the OBD connector
Old Jan 15, 2025 | 01:09 PM
Markoz28's Avatar
Markoz28
The obd killer is just killing the code that is popping up when you connect the obd killer, any other different code that pops up later different to that one won't be blocked
Are you saying it only clears codes related to the O2 sensor?
Old Jan 15, 2025 | 01:23 PM
7184RS's Avatar
7184RS
It register and clears the error that is on when you connect the OBD killer
Old Jan 15, 2025 | 04:14 PM
Markoz28's Avatar
Markoz28
So it will also clear if code was knock or fuel pump faulty or something worse?
Old Jan 15, 2025 | 04:17 PM
7184RS's Avatar
7184RS
It is not difficult to understand ...you install your OAP, as soon as your get a light you check the errors and verify that it is the PXXXX related to OPF , you connect the OBD killer it registers that code and it will clear JUST that error next time it pops up
Old May 6, 2025 | 02:21 PM
Dicecal's Avatar
Dicecal
I installed sport cats on my 2024 TTS. P0420, P0430 and CEL. I purchased the OBD killer directly from the company in Germany. Instant and excellent communication, the device does not do ECU resets and will only clear a limited amount of Cat and GPF codes. Cleared the CEL and codes within the first few minutes of driving. Very satisfied with the device for now, as I don’t want to program the ECU from OEM at this time.
Old Jul 21, 2025 | 12:55 PM
Gian6's Avatar
Gian6
Once the codes are cleared can you remove It?
When remove how many miles can you drive before you're forced to plug it again?
I would not want to leave it always plugged
