I finally got an allocation for a TTS with Oct 17th lock and Dec build and ETA Jan 2024.
As the SA was submitting the order, option P86 (Exterior Package in High Gloss Black) came back as 'stop sale'. As reported on other threads, Sports Design Package with many common black gloss parts is still available but I am not a fan. As a back-up I added rear Intakes in GB (mirror base in GB was already in the build) but still need to figure out how to get the side skirts and rear diffuser in GB. I think I can live with the from intake as is. In the order of preference I am exploring these options
1. Order the two parts in GB and swamp them at delivery time. Does anyone know where I can order these from ?
a. Side Skirts: Found 'paintable' skirts from Suncoast but not already painted in GB which I prefer.
b. Rear Diffuser: Can not find anywhere except for the aftermarket options like Techart
2. Order only Side skirts in GB (need help to point me where to buy as stated above). This will make the mirror base, rear inlet and skirt match. I can have the rear diffuser painted in GB after delivery. I am in SF Bay Area so any recommendations would be appreciated
3. Get both parts painted after delivery. I am in SF Bay Area so any recommendations would be appreciated.
The reason I prefer 2 over 3 is it takes care of the side of the car and gives me time to see if I can live with the rear diffuser in matt since the front intakes will be the same.
Any help of source for GB parts as well as recommendation for a reputable bodyshop will be highly appreciated.
When I had my Aventurine 992 TTS they told me the rear diffuser was not easy to wrap and have it hold due to the heat. You might be better off just sticking with the black plastic, or be careful where you go - find a really good body shop to do the gloss black items, not all shops are created equal.
Added GT3 skirts to my 2022 Targa 4 GTS with the Exterior Package in High Gloss Black and then PPFed. It's been a year and no chips, dings or scrapes present. Done by a Porsche shop who did some serious sanding and prep work. Gloss skirts look perfect with the high gloss package.
Doing nothing is an option I can look into once the car arrives. Knowing that mirror, intake and skirts don't match I will certainly be staring at them every time I get near the car though
I live in Austin, TX so no advice on where to get them painted.
I had the intakes painted (bought the car used and it was not spec'd as GB). It was $250, which was cheaper (confirming what eclou said).
My wrap guy put some GB film on the intakes as an alternative to painting them, but it looked wrong.
The skirts, rear diffuser and front area was spec'd as GB, I couldn't stop staring at the unpaintedside scoops, so I know where you are coming from.
All the GB as been clear wrapped and that has worked fine.
I would recommend clear wrapping everything that is GB (for me that adds the wing and the area around the sunroof as well as the bottom of the CF side view mirrors).
Yes, will get it wrapped at the dealer. At this point they are saying all painted surfaces will be wrapped so not sure about the Sunroof since I went with the glass roof. I am debating with them that all GB area can be wrapped because the 'plastic' texture is sanded down for paint. This includes the mirror base and the side intakes.
I tried wrapping GT3 sideskirts with a carbon wrap. It will keep bubbling no matter what. Front lip is fine.
did you wrap the front intake slats as well or just the side walls ? I have not looked into the front but if it can be wrapped that will be best. I am sure painting those will be costly due to the removing and remounting the parts
