Brabus blow off adapter?
Hi! I've seen this product by accident: https://www.brabus.com/en/cars/tunin...-740-5000.html
If I understand correctly, it amplifies blow-off turbo sound. Has anyone used it? As I'm a total noob regarding engine mechanics, this might be a noob question, but could it mess up something with the engine / warranty, or it is only affecting the sound?
@Jking911 thanks a lot for the info! Keep me posted please in case you know more. Btw, do you know if it does void / affect warranty in any way?
I have race exhaust, Do88 inlets and BMC filters. Tons of turbo blowoff noise, not the traditional Supra noise, but I can hear quite a bit of the turbo noise.
*I also have light weight package so that could also be contributing
@Jking911 Is this spacer causing any performance drop? I'm thinking this way – if BOV is used for releasing the pressure when the gas pedal is off, it releases it to internal system, not outside. This internal system ca use the air velocity to help build boost pressure again. If we release it out, we don't have this velocity anymore. Do I understand that correctly, or am I overthinking and this spacer does not affect performance in any way?
3 bolt holes comes with longer screws and fits between BOV and turbo housing. The side holes is the VTA part, and center section is the recirculate part.
pman3 (09-21-2023)
The following 2 users liked this post by Jking911:
MovingChicane (07-04-2024),
pman3 (09-21-2023)
