992 Turbo and Turbo S 2019-Current
Sponsored by: Porsche San Francisco
Shell 91 vs petro canada 94
Old 09-04-2023, 12:10 AM
911_MRL
911_MRL's Avatar
Default Shell 91 vs petro canada 94
Hey,
I got delivery of my 992 turbo s 2 days ago and I had to refuel within the first day. I put in 94 octane from Petro Canada and on the 2nd day I tried to do a pull and the car was revving up to 6k rpm but it wasn’t going fast it. I’m wondering if it was for the 94 octane with10% ethanol. With a bit of research I found that Shell 91,93 is far better than any 94 octane. But I’m not sure if I should use shell 91 since the recommend is 93 premium octane. Please let me know. Also I don’t really care about the break in period but I didn’t full throttle it yet, I still go fast on the highway with half throttle or a bit more. Sometimes I cross the 6k rpm line with half throttle
Old 09-04-2023, 01:44 AM
22CarreraS
22CarreraS's Avatar
If you dont care about the break in, why do you care about the fuel? You can do more damage during break in hitting high RPM than using the wrong fuel. Anyone that thinks 91 octane is better than 94 is why we have instructions on shampoo bottles.
Old 09-04-2023, 01:54 AM
Angryinch
Angryinch's Avatar
Received 1,095 Likes on 653 Posts
Shell 93 is the best fuel in Alberta.
Apparently, Chevron 94 with 10% ethanol is really good in BC
Petro94 is decent.
Don't use 91, the car will pull timing.
These cars heat soak pretty bad and don't like hot/humid weather.
Old 09-05-2023, 08:01 AM
CanAutM3
CanAutM3's Avatar
Received 1,310 Likes on 613 Posts
PetroCanada 94 is one of the best fuels for power in Canada, particularly for us in the east where it’s the only 93+ available. The 10% ethanol is actually good for performance as it improves octane and also has slightly more energy content per mass flow of air inducted. Stay away of the 92/91 fuels.
See video below, skip to 17:50 for the test results summary:
https://m.youtube.com/watch?v=SoCsF5dRE0U&t=1080s&pp=ygUfQXVkaSBiZXN0IGZ1ZWwgaW4gY2FuYWRhIHN1b W1lcg%3D%3D
Old 09-05-2023, 10:56 AM
Pad Bender
Pad Bender's Avatar
Received 1,286 Likes on 648 Posts
My stage 2 car runs great on PC 94. I can get 8.5L/100 on a highway run and then track with no issue.
Old 09-05-2023, 11:04 AM
Angryinch
Angryinch's Avatar
I find shell 93 to offer more performance than petro 94.
my logs with petro 94 would have some timing correction, with shell 93 I see very little timing correction.
my mustang buddies all get about 1-2 degrees more timing on shell 93 as well. (Boosted coyotes)
fyi
Old 09-05-2023, 11:10 AM
Mlarco52
Mlarco52's Avatar
fyi
How about chevron 94?
Old 09-05-2023, 11:16 AM
Angryinch
Angryinch's Avatar
In AB chevron 94 non ethanol is absolute garbage you might as well run 91.
however chevron 94 w/ 10 percent ethanol in BC seems to be a better fuel and I have heard works really well.
If you’re tuned, try different fuels and see what holds more timing.
Mlarco52 (09-05-2023)
Old 09-05-2023, 10:00 PM
MaxLTV
MaxLTV's Avatar
Received 1,214 Likes on 598 Posts
I'm in BC and all Chevron stations around say that 94 has no ethanol. And it's noticeably worse than Shell 93, so it seems that it's without ethanol.
Ranking by my experience in a tuned 992 TTS in GVA:
Shell 93
Petro Canada 94 with Ethanol
Chevron 94
Shell 91
Other 91
Angryinch (09-06-2023)
Old 09-06-2023, 02:53 AM
Angryinch
Angryinch's Avatar
Nice thanks for the input, seems like shell 93 FTW.
shrimp money (09-06-2023)
Old 09-06-2023, 08:26 AM
Quadcammer
Quadcammer's Avatar
Received 1,389 Likes on 806 Posts
This entire post is wrong
The following 2 users liked this post by Quadcammer:
911dude41 (09-06-2023), MaxLTV (09-06-2023)
Old 09-06-2023, 04:39 PM
CarManDSL
CarManDSL's Avatar
deleted
Old 09-06-2023, 05:07 PM
911dude41
911dude41's Avatar
Received 1,227 Likes on 705 Posts
Ethanol is good. Not bad unless you're messing with early 90's engines and lawn mowers.
When I lived in Canada 94 octane used to be found at Sunoco stations. Now it's Petro Canada. Has it changed or is it still sourced from Sunoco?
I too have heard bad things from tuners about the 94 octane nowadays. Doesn't make sense to me but haven't been bothered to research it as I no longer live there.
Old 09-06-2023, 07:29 PM
MaxLTV
MaxLTV's Avatar
Petro Canada and Sunoco are both brands of the same company - Suncor. So they just swap the brand names back and forth. But it's almost certainly the same stuff.
Old 09-07-2023, 01:16 AM
CanAutM3
CanAutM3's Avatar
I believe there is more complexity to it. Suncor and the US based Sunoco company are no longer directly related. For instance, in Quebec, Sunoco gas stations were acquired by Ultramar in the late ‘70 and all Sunoco gas stations were converted to the Ultramar brand in 1997 with ensuing product standardization (that’s when we lost the Sunoco 94). In other provinces, Suncor was using the Sunoco brand name from their Canadian origin until it merged with Petro-Canada in 2009. Petro-Canada was offering 94 fuel well before the merger with Suncor in 2009.
Quick Reply: Shell 91 vs petro canada 94
