992 turbo s quarter mile
Has anyone with a 992 turbo s broke into the 9s stock? I remember seeing an article on here that a 992 turbo s ran a 9.8 flat at 138.9 mph an hour 0-60 in 2.3 seconds, but the article has been deleted. I saw the screenshot of the gps and it said that the guy had no mods so I just wanna confirm and I think on a prepared surface the 992 turbo s can actually hit 0-60 in 2.2 seconds without one foot rollout.
Multiple sources have recorded 2.1 0-60mph on unprepared surfaces (CarWow, MotorTrend) as well as 1/4mi times as low as 10.1 seconds consistently
There was even a test (can't recall the source; will try to find it) between the 992 TTS and Model S Plaid that recorded TTS @ 2.0 0-60 and 10.0 1/4mi
Yet to see anything breaking 2 seconds to 60 or under 10 flat in the quarter. Would be cool to see though!
I haven't seen any turbo S stock in the low 2s WITHOUT a 1ft roll out... Without a rollout, its modified stage2+ cars into the low 2s and no one has broke into the 1s.
Nor have I seen anyone in the 9s stock except those magazines. Maybe they are using a 1ft roll out in their 1/4 runs too ha.
Check on draggy. It takes a tune to get into the 9s typically. These cars are low 10s stock. I have light weight package (no LWB seats), when the car lands, will start a thread with stock times/dyno and modified. I have bought everything that M engineering sells for this platform already![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
This is the only one I have seen. Car and Driver testing the lightweight package. I am unaware any owners reproducing it, so I suspect alignment of all the planets is required.
https://www.caranddriver.com/reviews...y-the-numbers/
This is the only one I have seen. Car and Driver testing the lightweight package. I am unaware any owners reproducing it, so I suspect alignment of all the planets is required. https://www.caranddriver.com/reviews...y-the-numbers/
Yes, two mags have hit 9s with lightweight package. I don’t know anyone that has replicated it.
Remember those numbers are corrected for sea level I believe…
