TPMS display
-you probably need to reset the computer (push down & hold on center of vol control button) - call your shop to confirm steps as i've only done it one time due to connectivity issues with my iphone
-recently my TPMS went to displaying Deviated Pressure psi only (only when the car is stationary) - deviated pressures from the Comfort or Full Load (from your selection in car/tire set-up)
-it should display actual pressure, so the shop tech called to step me thru the reset steps, i just haven't returned his call yet
2021 TTS Cab
2021 TTS Cab
I'm not sure it measures the actual temperature b/c whether it's 90 degrees outside or 30, the temp indicator always starts on the low end. Perhaps it's just measuring deviation as calculated by pressure change? Anyone know?
It is measuring actual temperatures and requires the appropriate sensors in the wheels. When I install my winter wheels that only have the pressure sensors, the temperature bar no longer displays.
2021 TTS Cab
2021 TTS Cab
RD16RR (01-16-2023)
