In anticipation of my incoming TTS with LWP, I have been killing time watching every Turbo S video and reading every Turbo S article out there. I can't help but notice a really large range for 1/4 mile times and trap speeds. I see numbers as high as 10.8 @ 126 mph as well as 9.9@139. I understand there is some correction involved in some of the magazine numbers but this variation is quite a bit high. Has anyone here gone to a drag strip and can post a slip OR has draggy/vbox numbers of a stock car, with stock tires, and pump gas?
I was just thinking of posting this myself and wondering the same.
I will be into drag racing with the new TTS. Downpipes/tune for sure, maybe upgraded turbos.
I don't see a lot of mod posts on here or even 1/4 info etc. Would be curious on some real info from members. Once I have my car, I will post all stock and modified results in a thread/journal.
You should consider meth for any serious upgrades to the car. ES Motors with all the mods plus meth are doing 9.4x 1/4 and 150+ mph. I doubt those numbers are possible without meth
I can add one data point. Totally stock as delivered on a typical crowned somewhat bumpy rural road. Just past 1800 mile break-in. OEM Goodyear tires. Probably could do better with Cup 2 tires and a prepped surface. Slight up slope at the end probably didn’t help.
With a 1.59 sixty hooking well on the street, you just posted a real world Data Point. That falls right in the middle of all of the CarWow videos. 0FT DA would put you at their low number . Well done !
R8 will kill all on roll races, they are beasts and big HP.
The TTS moves out hard from a dig, Jesus!
Stock wise and not an R8, but I have done a couple of pulls from 50mph against a 2022 huracan conv and I was pulling on him and ahead by 2 car lengths when we decided to call it quits (around 110)
