Hi all! I just took delivery of my 992 2022 Turbo. I am wanting to purchase the torque and breaker bar tools for the centerlock socket that came with the car. The socket is 1" driver needed instead of the usual 3/4" that it was before. Any suggestions as to what options are out there?
My manual also states the "1" square fitting" but the socket that came with my car in 3/4". Maybe it is a typo in the manual. Did you check your actual socket?
I highly recommend getting the Neiko 03715B torque multiplier wrench. It is far more compact than the massive 4~5' long breaker bar and torque wrench. I purchased mine last year and it works like a charm. Since I track my car, I take my wheels on and off quite regularly for tire rotations or brake pads replacement. It is compact enough to fit in my track side toolbox that I carry with me and works with my existing breaker bar and torque wrench.
It’s in the small compartment located top right in the frunk, alongside the toe hook.
Much appreciated, sure enough... its there, whats that bottle of goo (I have no idea whats inside, it just seems heavy), thats also in there? I didnt think you needed anything for run flat tires.
Not bad, only $240.00 - $280 bepending on which size, do you know which one we need??:
3/4 drive (2,200 ft-lb)
1/2 drive (1,100 ft-lb)
Also any value in this variant? it has some attachment, but otherwise seems the same:
I got the on with the 1/2" input drive. The torque rating is more than sufficient and it is compatible with my existing 1/2" breaker bar and torque wrench.
I’m confused here- it’s a torque multiplier and more compact than your 4-5’ breaker bar but you later say that it works with your existing torque wrench and breaker bar. So I guess it enhances torque but not enough to replace the breaker bar? I’ve never removed CL wheels so I’m not exactly sure what works best. Thanks for helping me to understand.
that bottle of goo is tire sealant. The tires are not run flats.
