What I was looking for is the (hidden) PSI bar gauge that I could easily see in the periphery of my vision without taking my eyes off the road...aka being able to move the (hidden) PSI bar display to the condensed display instead of outside temp or something..
I am not sure I follow you. I just explained how you can have it directly in your field of view...
I have owned several 911's, the most recent was the 991.2 and NONE of them had the side gauges covered by the steering wheel. 5'11" is normal height, so I dont think I am overly tall or overly short to be the exception. Even reviewers of the 992 have complained about this. I am also 90% blocked by the wheel and to see the gauges I have to move far more than a few degrees, I have to take my eyes off the road and peer around the wheel. Its a design flaw that they made to squeeze in the giant center screen and digital gauges. This and the buggy PCM are the only 2 flaws I have with the 992's.
They need to rework the gauge positions/ size / maybe even the tach too and add more hot buttons / more intuitiveness to the 992.2 controls. While you're at it, remove the rear seats as a std. feature to trim some weight.
Yes I have the same cluster of temps and boost pressure in the normal view as you have shown. I wanted a much bigger gauge so I don't have to take my eyes off the road. As I suggested something could be done in the condensed view. Hasty photoshop below. A flat bar gauge would look better but you get the idea...I'd rather have a big honking PSI boost gauge than the time or outside temp.
OK, understood. Having a 2021, I am not familiar with the “condensed view”.
So I've got my "custom" set up for the track exactly as in post #16. Catch is that I've never seen the boost gauge function, even on track days.
Am I missing something or.....?
