Sports exhaust vs normal exhaust - can we revisit this again for new comers?
How much better does the Sports exhaust sound? Does it do anything else for the car? Is it worth $3500? Pros and cons? Thanks for the help.
Mine has Sports Exhaust. I chose it for the look. From what i've seen, almost all TT/TTS were ordered with the sports exhaust. I've only seen one (maybe two) TTS with regular 4-pipe exhaust. I like the sound of mine but not sure if the regular exhaust sounds any different or worse. Since the sport exhaust appears to be the new look (the new norm) it might be harder to resell the car without the sports exhaust???
In normal mode, it's stealthy. Very quiet.
Noticeably louder in SPORT but not "look at me" or "rice rocket" loud. I tried the full GMG exhaust for a week and it was just incredibly loud. Did it sound great? Of course it did. GMG makes great products. But so did my Supercharged Suburban with a Corsa exhaust (drone monster....put in Walker Quietflow for Chevy's -- problem solved).
The problem was the GMG system was just too loud for my daily use. So I went back to stock.
In Sport OEM mode, you pick up some nice rumbles that are fun without being annoying. I really like it. Others will find it lacking.
Here's the rub though -- if GMG or someone else could create a center delete (like they did on my .2 GT3) where I could use Normal mode for full stealth and Sport mode for "Holy Bleep" mode, I would do it. I would buy it in heartbeat.
In normal mode, many of these exhausts are still just really loud. And I couldn't have that for my particular application. I understand there is a valve issue in play here (harder to trick the valves, etc) but WOW is there a market opportunity for someone that cracks the code there. Even if Normal mode becomes as loud as Sport OEM mode and the then REVISED SPORT MODE is "holy hell loud mode" -- I would buy that. And pay a lot. I just need a quieter mode for around the town driving.
Maybe this is just wishful thinking and it's impossible. Don't know.
the stock and PSE exhaust is basically the same. Don't let Porsche fool you on the matter. You can even get the valves to open on demand with the stock unit (custom programming by your friendly dealer).
https://rennlist.com/forums/992/1185...-possible.html
Sport exhaust sounds a little better and looks a little better IMO, I replaced the stock exhaust with Kline headers, catless and Kline exhaust, my car was ordered with the sport exhaust, in normal mode exhaust valves closed my car is slightly louder than stock, zero drone, in sport mode and sport plus it sounds more like a V8, and half to full throttle it screams like you can not believe a 6 cylinder could make that noise. The standard exhaust much like the 991 exhaust I had and modded on several 991's, unless you add valves you have no control of exhaust noise
wotaskd (07-01-2022)
Not correct as the standard unit has the same valves as the sports option. And for an hour of labor at the dealer you will get the same control as the sport exhaust.
Or for those of us who like our speed silent - can the sport exhaust be made to be as quiet as the non-sport? My casual testing says that both modes of the sport exhaust are louder than the non-sport, but I would like to hear other test results.
Valved exhaust is the solution if you go aftemarket. I have JCR valved titanium and it is conference call friendly in normal/closed and just rips on throttle when opened up.
The PSE with sport cats sounds pretty descent...more turbo whistle and throatier down low. A must IMHO.
I have seen this testimony from aftermarket developers...apparently the valve functionality can be unlocked with the non PSE. You would then control valve functioning from your touch screen.
The following 2 users liked this post by carhillclimb:
cptcolo0 (06-11-2024),
Denny Swift (07-03-2022)
I’m sure I’m in the minority, but in my GTS (PSE standard), the car is a bit too loud (borderline obnoxious) WITHOUT the PSE engaged. With PSE engaged it’s absurdly loud and the farts are far too juvenile and embarrassing sounding for my taste. Overall, the exhaust sound in standard mode is quite nice, but just a bit too loud for me. Every time I hear any loud car drive by, I just cringe and am embarrassed for the owner. One of the most appealing things about Porsche is that their styling is understated elegance and beauty. They don’t scream, “look at me!” as nearly every other car in this category does. I think a loud exhaust on a Porsche is antithetical to their ethos.
At the end of the day some prefer the look of one versus the other and that's what should drive what one should buy. I was just sharing you can achieve the same valve control with the stock one.
