New HRE R101LW Installed on 22 Turbo S
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/1_377f73ec90f4a0d20e23b82b5d5aebef89dd82f2.jpg)
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/2_ce19c2f7e0b9f62fe02194821d3b6bc7a660bfe0.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/3_9cbf1169c9083a6b735dcb077d31c53a071fbb55.jpg)
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/2000x2000/4_baf9fd719ebc0334b12ecd7182fc53e23919682e.jpg)
OEM wheels were exclusive design
Front w/Pirelli tires are 47#ea
Rear w/Pirelli tires are 63#ea
HRE R101 LW brushed dark clear finish
Front 21x9.5 w/MPS4S 255/30/21 tires are 46#ea
Rears 22x12.5 w/MPS4S 335/25/21 tires are 58#ea
12# saved total!
(H&R lowering springs installed)
Thanks David @ Wheels Boutique for the spot on fitment!
The following 12 users liked this post by jvise78:
boosted305 (06-04-2022),
Calbenzo (06-02-2022),
cavemanmoore (10-04-2023),
criss (06-01-2022),
Feld (06-02-2022),
and 7 others liked this post.
Are you stating that you saved a total of 12lbs (approximately 3lbs per wheel) going from the stock Exclusive Design wheels/tires to the HRE LW wheels/tires?
Just re read your post again..
You saved 1lb on each of the front wheels (2lbs total)
and 5lbs on each of the rear wheels (10lbs total)
If this is accurate, then my previous posts on another thread were spot on. Only the HRE LW wheels are lighter than the OEM EXCLUSIVE DESIGN wheels. ALL of the other HRE wheels are heavier than the stock ED WHEELS. People were telling me I was crazy and I knew I read this somewhere.
David at Wheels Boutique, now you got the numbers...
Thank you for taking the time to weigh them and post!!
shrimp money (06-01-2022)
HREs are 12.5 instead of ED 12.0...so perhaps even more relative savings.
The ED centrelocks are surprisingly weight efficient in design when you see them from the back...
My sole reason for buying an aftermarket wheel is performance. I see no reason to buy an aftermarket wheel that is as heavy or heavier than the stock wheel because you sacrifice performance for aesthetics. When the wheel is lighter, then you get the aesthetics AND the performance as you do with the lightweight HRE's. I had the same wheels on my 991.2 Targa and loved them. Looking at the factory ED wheels, I was wondering if any aftermarket wheels were actually lighter. I knew the HRE LW had to be lighter because they are one of the lightest wheels manufactured that isn't carbon fiber. But, the new 992 wheels, both the ED and the standard 5 spoke design are VERY light. Which is why I started looking into what wheels could be purchased that are lighter than what Porsche offers. It seems only the LW BBS and LW HRE are and none of the others are.
So, from a performance standpoint, only these two would perform better than stock. That was the point I was trying to make 6 months ago when I jumped in on that other thread about wheel weights.
You are correct, they are 1" larger and still lighter, so it is safe to assume that in the same size they will be even lighter.
Now that we have the actual weight of the OED ED wheels and tires, it should be easy to compare them with any other AM wheels.
Did you purchase a 21/22" setup? I like you only will buy if there is a tangible improvement in weight savings without sacrificing strength. For track wheels I would consider going to a 20/20" setup for more options with better weight/cost/performance values
The Michelin PS4S are 25# front and 34# rear according to Tire Rack. That means the HRE R101LW are 46 - 25 = 21# front and 58-34 = 24# rear.
Even with the larger diameter the wheel weight savings is 3# each front and 7# each rear!
