Ctek Battery Tender
#32
https://amazon.com/CTEK-56-260-Comfo...snx131-20&th=1
Do these stay connected to the car 100% of the time and then you just disconnect the clip when not on the charger?
#33
Thanks, aware of this, but i got different opinions even from dealers, some say to put the negative on battery and some including manual says to put on pole on side of body.
I was wondering what most people do with lithium battery.
This year i did the 12 volt, but had to reset because of power failure, want to avoid in future
#34
I use the negative post on the body, that is what the manual says to do.
i think if you do it this way there is some surge or protection perhaps?
Pinodm (03-24-2024)
The following 2 users liked this post by DemonBarber:
Pinodm (03-24-2024),
Ray Benson (03-24-2024)
#36
Booster on negative post for sure. Trickle charger can go on post or cross bar. I have seen some people hook up the eylets to the directly to positve and negative terminal too.
Negative post definitely charges the most reliably and safely.
