Max boost psi TTS?
Curious to know what max psi boost reading you all are experiencing with your 992 TTS’ in either Normal, Sport or Sport+ mode. Also, if that max psi reading increases however slight when Sport Response is activated?
Thanks in advance. Currently still in break-in and keeping the revs around 4k and just want a frame of reference.
On full acceleration in sport which is where I drive most often and during favorable atmospheric conditions….on the boost gauge which is hard to see 23 psi is my max…. most of the time 19_22…I did a post on this awhile back nobody replied???
topherserrano (10-11-2021)
Last I checked on Sport mode, I was consistently at maxing out at 18psi from 3k-5k rpm, at wide open throttle.
I wonder what parameters contributes how much boost is delivered.
Anyone else care to share their results/observations?
I’ve also rearranged my right dial to include boost pressure along with Coolant Temp, Oil Temp, Etc. since the steering wheel blocks the view of the far right fuel and boost gauge dial.
