Battery
So after being apart for one full week without movement I go to start it this morning battery’s dead. Does have the key fob in the car affect battery drainage?
It sat for 6 days.
It sat for 6 days.
Yikes, this makes no sense and I don't think it's normal. I hope others chime in but I hope it's a simple fix.
This is incomprehensible, unless something did remain on... I am irritated by the fact that every time you walk past it, it unlocks all by itself. I never left the key inside the car, so I have no experience of
this problem, but these cars ar NEW ! So are their batteries... it seems very unlikely that it emptied itself in such a short time, unless something was turned on, somewhere. The guarantee is running, call
the Porsche Centre so they come and collect it !
Sorry about that! I went through this with my car after getting PPF done. These cars have a lithium battery with a low-power shut off function. When the power drops below a certain level, the battery essentially disconnects itself from the car, so that you get zero power. The good news is that the battery isn't really dead. It just needs to be turned back on (for lack of better explanation) and it should still have enough juice to start the car and get recharged by the charging system.
In my case, the front trunk was locked shut, so I couldn't even get to the battery. If that's your situation, you'll need to pull the fuse box cover off in the driver footwell and look for the red trunk-opening jumper. You need to pull that jumper out (all the way!) and then apply 12v to that jumper and ground to the door latch or other clean chassis ground. You can use a charger or jumper cables from another car. If using a charger, just be sure it is set to deliver 12 volts whether or not it detects a battery. Many of the new smart chargers won't deliver power if they don't detect a battery, which they won't if the battery has shut itself off. Some chargers claim to have a mode for that, but I had no luck using them and instead used an old fashion always-on 12 volt battery charger. Once the trunk is open, you can remove the black plastic cover (no tools, just pull) at the back of the trunk, then apply 12 v to the positive battery posts and ground to the special ground post to the right of the battery. The battery should click back on within a few short minutes. Once it does, you can start the car and drive it around to charge it up. Hope that helps.
Of course, you can also call for roadside assistance and/or your dealer, especially if the car continues to die after 6 days. That's too short. But... in my case, the battery shut off after 4 day, I believe because the PPF guy had the key in his pocket and was constantly waking up the car (unintentionally) and draining power.
I hope it ain't so, but you may also find that even after getting the car jump started you could get a low battery warning that won't clear even after everything has been recharged. So far, I know of two of us (who lack the equipment to clear codes) have had to take cars to the dealer to get the low battery warning to go away. Porsche seems to have some 992 bugs that they need to work out.
JuanilloTurboS (03-27-2021)
Great info guys!
Had to leave to a class in a rush early this am, was really bummed about not getting to drive it today. Actually sitting in class now LOL!
Guess ill call road side assist on the way home so I can meet-em ther.
Monday il lask service advisor if leaving key in car has anything todo with it.
Im guessing it does ifit keeps looking or waking the car up since its within range.
Make sure you keep your battery jumpers (i have a NOCO boost plus GB40) tucked behind your rear back seat...!
You will be able to get in manually with your key and save you from not having cables to jump the fuse box to open the trunk.
Edit: maybe I misread your earlier post. I think you are saying to keep the charger inside the car so that you can use it on the fuse-box jumper to open the trunk. If so, good advice.
Had to jump the frunk through driver side access, switch wouldnt work needed to use key fob. Was able to jump start battery after that.
Did leave check engine light on tho,
Any way to pull up on PCM to see what that is? Gave up looking this am.
Thanks and understood. But once you get into the car, there's no way to open the trunk and get to the battery without the jumper in the fuse box, since the battery is shut off and essentially disconnected from the cigarette lighter. Right? That's what my owners manual seems to suggest, and certainly consistent with all my floundering when my battery shut down...? Did I miss a trick?
Edit: maybe I misread your earlier post. I think you are saying to keep the charger inside the car so that you can use it on the fuse-box jumper to open the trunk. If so, good advice.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
NOCO units worked for my buddy in getting the trunk to release via fuse charge and then car to start via trunk access.
Huge PITA for a battery that is turning out to be temperamental.
Well after driving it most of the day Sunday, the check engine light went away. Hooked up the Porsche trickle charger, seems to get disconnected, has anyone tried using the mode button to wake up the battery?
