How to program homelink
I had no problem programing the homelink but it will only pop up on the screen 1 out of 10 when i am leaving or carriving to the house. I programed the diamond button on the left side of the steering wheel to connect homelink. Just push it if you don't see it on the screen.
I feel like this is Porsche's 'BMW no detent turn signal moment' they went and made something very simple, very dumb for no good reason. Note BMW finally gave up on the no turn signal detent around 2018 and went back to having a detent.
hcvone (06-06-2021)
I'm not feeling great about how difficult it can be to programing Homelink, but then to have it only work occasionally once programed, is a bit much!
I decided to purchase a set of garage door openers from Amazon for less than $15.00, I will program them, problem solved!!!
Received 2,672 Likes
I've been using a combination that works extremely well. A hard wired Button on the wall, Alexa, a system called TailWind and Homelink.
When I enter the garage I push the Button on the wall and the garage door opens -or- I can ask Alexa to do it.
When I leave, TailWind closes the garage door automatically as I leave it's sensing perimeter, and this distance can be adjusted on their app.
When I return Tailwind opens the garage door, when I'm about a block away. This distance can also be adjusted on their app.
As I pull into the garage HomeLink pops up and I can press that "X" on the PCM to close the garage door -or- I can ask Alexa to close the garage door -or- I can push the button on the wall.
HOWEVER . . . when all's said and done, why Porsche couldn't just have stayed with a button on the bottom of the rear view mirror is completely lost on me. IMHO it's a tech geeks solution to a problem that didn't exist!
My only guess is that software code costs a lot less, and can be adapted to more platforms, than buttons. I've worked out a fairly efficient approach with the GPS and diamond button on the steering wheel. Not as good as an old-fashion button, but not bad now. My only remaining nit is that I wish there were someway to close the doors without getting out of the back up screen. As is, I back out, put it in park, close the doors, and put it back in reverse -- which seems needlessly cumbersome when any entry-level car on the market is easier. But hey, at least we don't have to pull the motor out to change spark plugs....
I thought I was going crazy trying to make Homelink work properly. Tesla has this figured out. They do the exact same thing, and it works perfectly, including the Homelink locations appear on top of the rear view camera image when backing up.
It actually works fine once you get the hang of it. It's the user that has to be trained lol.
I have one of the custom button programmed for homelink, When I get relatively close to the house, I click on that button and the center screen will populate what you have programmed. if you program your garages with location turned on, once you get close to your house (around 50 feet), the choices will pop. A solid tap on the name with your finger (screen will acknowledge the input with a little "strength signal" for a second) works just fine. Practice with it a few times and you will quickly find the right way to tap the screen so that it sends the signal.
My only issue is in the morning while PCM syncs my iphone, I cannot access the homelink and have to wait for it.
Valid point from Tom that doing it with PCM rather than separate buttons is probably cheaper and easier for Porsche.
On the positive side of things, it did save us a few grams and if it does not work well, Porsche can fix it with a software update.
The automatic opening features of other systems do not work for me as I keep dogs in the garage and I sometimes do not want the doors opened when I come home.
Steve 96C4S (06-11-2021)
Just as a FYI - it may not be possible with all devices. I ended up getting a MyQ Wifi opener + remote which could also be paired with the car's Homelink (the stupid unit the house had couldn't pair before, even though it was listed as Showbox jiofi.local.html tplinklogin supported).
