992 Turbo vs Turbo S hardware
Hello folks. My question is primarily on the Turbochargers. Can not find any info if the sizes are the same on the Turbo / S. Can someone chime in? Thanks ahead!
Someone recently posted the press releases. The difference resides in the compressor wheel of the turbo, where the base turbo has 59mm wheel while the turbo-S has a 61mm wheel. Both share the same 55mm turbine wheel size.
Basic Sponsor
If you are planning to upgrade the turbos than the cars will be identical in terms of turbos.
WORLD MOTORSPORTS
2170 W 190th Street Torrance, CA 90504
(310) 533-8900
- Akrapovic - BMC - TechArt - H&R - By Design - AMS - CSF - Kline - NGK - TiLugs - HRE - M Engineering - ID Injectors -
FULL SERVICE INSTALLATION FACILITY - STATE OF THE ART WIND TUNNEL DYNO - ECU TUNING
WORLD-MOTORSPORTS.COM
(310) 533-8900
