Just took delivery!
#31
Thanks!
Majority of top wheel manufacturers can accommodate center lock or 5 lug, but not all tire shops can and neither can I.
My primary reason for 5 lug was I switch between Winter and Summer wheels. Feels silly having to take them to dealer to get them swapped twice a year. I can easily swap all 4 wheels in my garage in 30 min or so with no added hassle. Additionally, if I ever need to take a wheel off for whatever reason, I can do it, unlike with center locks.
#33
That can be done with sport design or packages.
#34
With respect to everyone who "prefers" center locks, I disagree with all of you due to real world practicality of the 5 lug hub. Stronger this stronger that, it is all irrelevant in the real world. I prefer real world practicality over LeMans cool factors, but to each their own. Center locks are more complex, have more parts/pins and its a procedure, not to mention tools aren't readily available.
So unless you track your car, with a pit crew and are looking for a shorter pit stop, I don't see the point. For my version of the real world, I dont get the point of centerlock on the street. Just my personal simplistic opinion on the matter.
Admittedly, if you have the right equipment and after doing the wheel changes a few times it would get easier, but either way you are loosing real world practicality that comes with a traditional 5 lug configuration. Congrats no one else can take your wheel off but you, few rennlisters, and the dealer.
To me the real world disadvantages outweigh the track advantages.
Bottom line is, center locks, just like the ignition key on the left side of the steering column, pay homage to Porsche Racing heritage and that's all it is. One isn't better than the other.
If you dont know why the ignition key is on the left side of the steering column, it is so because LeMans race starts with the driver outside of the vehicle. The idea is, as you get into the car, your right hand on shifter/steering wheel and left hand on ignition, so you can do two things at once and get off the line quicker. No practical reason for it's location besides that. Same goes for Centerlocks.
The above is just my opinion anyone is welcome to disagree. Which ever way you configure your vehicle, neither is wrong, worse, or better. Depends on your priorities.
Thank you and yes, its part of the configurator...
See screenshot below.
#35
I ordered the CL on my TT simply because I preferred the look of the S alloys. Checking my local tool shop and they have both 3/4 breaker bars and torque wrench. Wasn’t sure if the CL socket comes with the car as standard or if it’s ordered as an extra ?
#36
The center lock removal procedure (no pit crew needed):
1. Remove socket from trunk (Porsche provides the magic device...its in the truck)
2. Place said socket on torque wrench (this special tool can be purchased online from Amazon)
3. Loosen center lock
4. Jack up car
5. Remove wheel and replace
6. Place center lock back on wheel.
7. Drop car
8. Torque to 450lbs
* embarrassing to have to post this but people who are clueless need to be corrected.
4. Jack up car
7. Drop car
8. Torque to 450lbs
The following 5 users liked this post by ggreg911:
Agentorange (11-18-2020),
CGT000 (11-19-2020),
ER911S (11-19-2020),
Ernesto Otero (11-18-2020),
P4bombers (08-06-2021)
#37
"Stronger this stronger that, it is all irrelevant in the real world. I prefer real world practicality over LeMans cool factors, but to each their own"
Lets discuss this:
1. If I am buying a car capable of 200+ mph ( i know i am the rare breed that do intend to drive this car at high speed) I want the strongest wheel configuration possible...very relevant in the real world to me.
2. is a TTS with 640hp really a "real world practical car"...I don't think so.....there are hundreds of other cars that are much better for those seeking "practicality" over "LeMans cool factor"
Lets discuss this:
#38
Lets discuss this:
Lets discuss this:
I gotta agree with that - if you want practical you can just take the bus
#39
4. Jack up car
7. Drop car
8. Torque to 450lbs
4. Jack up car
7. Drop car
8. Torque to 450lbs
I'm clueless....glad to be informed
....i'm just trying to figure out how its more difficult than 5 lugs, when there is only 1 item to loosen ?? .....simple though it may be....i'm glad you posted it
ER911S (11-19-2020)
#40
Lets discuss this:
Lets discuss this:
p.s. I think you missed where I was going with the "pitcrew" , you dont need one to do a tire change obviously. I'm stressing the point that it's a professional racing thing that's tricked down to every day 911 for no apparent reason. To you or me, there is no real world advantage one way or the other. You may prefer one way or the other, but your performance advantage does not exist... and neither does mine. Difference is anyone can take off my wheel, not everyone can take off your wheel, therefore, impractical lol... honestly it doesnt matter.
ER911S (11-19-2020)
#41
Edit to avoid misunderstandings... I'm not saying its a complex process, once you do it once or twice, isn't much to it at all.
992.tts (11-18-2020)
#42
Comes with the car. Lift the plastic under your trunk, it there.
#43
Received 2,672 Likes
ER911S (11-19-2020)
