RS understeers badly
I think if you're looking for low speed corner entry rotation (2nd gear, entering hairpins) you're benefitting from the Rake and stiffer sway bar in the rear. From there, I'd be messing with the steering wheel dials...but can assure you that if you're in the -4 range for bump/rebound etc that's gonna suck.
What about the torque vectoring and differential settings? I'd suggest looking there as the solution, and consider the tires / psi etc. 30PSI Hot is definitely a really low temp/pressure for a Pirelli. in the 992 Cup slicks they're running 29PSI hot- but I think you would be starting your sessions at 20-21 PSI and the car will drive crappy when they're that low. The sidewalls for pirelli street tires just don't do anything until you're at 25-26 from previous experience.
I'll try higher tire pressures too. I went low because I had Corsas blister in the middle last time I used them on a GT3 at 33-35 psi. But that was over 5 years ago, and these tires seem very different, even though the name is the same.
From: Mid-Atlantic (on land, not in the middle of the ocean)
AlexCeres (09-14-2024)
With the double wishbone suspension 4WS, PTV and aero, i don't think you are going to get understeer in the car unless the settings are off. To me, my GT3 handles like a mid-engine car.
laguna911 (09-18-2024)
front bar to full soft, and youre going to want to mess with the tire pressure for SURE...and I second CJ with torque vectoring settings here and maybe even the diff. Oh, and switch to a Michelin cup 2 or even Goodyear R comp...or the NEW Pirelli R comp at least...these corsas just dont do what I think they should though they are fine on a street.
The following 2 users liked this post by sechsgang:
AlexCeres (09-15-2024),
C.J. Ichiban (10-03-2024)
I finally got to drive my 992 RS on track. It's very impressive, but the experience was marred by unexpectedly strong understeer. I'm wondering what was wrong with my setup and how to dial it out.
Here is my alignment setup:
I can't see anything wrong there - does anything seem off? Also, P Zero Corsa N0 tires with about 30 psi front 33 psi rear hot.
I started out with bump and rebound at -4 (guess why - I forgot ) and diff at neutral settings, and the car would not rotate at all, even a quick lift in the middle of a corner that would normally make me spin like a ceiling fan barely tucked the nose in. I even turned off TC to make sure it's not nannies stopping any rotation, but it changed nothing. I remembered about the shock settings only by the end of the day and dialed shocks to 0 bump and +2 rebound, and the car got noticeably livelier on transitions but still would understeer a lot in steady-state cornering.
What am I missing?
Also, some other track impressions:
The OEM brake pads with PCCBs suck! Even my Turbo S had a better brake feel, and it's definitely the pads because everything feels great at lower loads and temperatures. The pads are just not robust.
Cooling is spectacular - I drove with windows up and AC on, on a 90-degree day, and everything was nice and child inside and the engine temps stayed quite low.
Corsas are so-so on the track: vague steering feel compared to sport cups, high wear (3 days will be a stretch for them, if possible at all), and they are too progressive so it's harder to notice when normal slip turns into excessive sliding, which makes it harder to keep the car precisely on the limit. But maybe it's me just being used to slicks - I have not driven a car on road-legal tires on track in over 2 years. In contrast, I liked Corsas a lot for road driving. They are more comfortable than Sport Cups and handle rain much better.
The drivetrain behaved impeccably - just pure joy.
DRS is fun. I was not pushing for lap times, but just pushing the button before every straight seemed to have a small positive effect and gave me something to do with my hands, given that PDK was shifting perfectly, so I did not need not shift via pedals. I could not see the car engaging DRS automatically ever - does it show it somewhere?
What am I missing?
This value should be measured with car with full tank, liquid levels fine, no driver and extra weights, don't know how was your car.
First I would check again alignment and height (maybe something went wrong while doing first time... and values were not reliable), if measure was/is correct...try again corner weight with full tank and no driver, if measures were not correct...do the right alignment/height then corner weight.
Maybe this helps in identifying what's wrong with you car, from my experience 992 RS is almost understeer-free
TRAKCAR (09-18-2024)
arcamalpha (09-19-2024)
Max, my setup factory rake, I have zero degree toe in front, not toe out at all and mild camber, lowered -3mm all around, bars in the middle.
Dials -2 comp and reb front and rear, Ring recommended setup absolutely no understeer. My overall experience is that the car rotates much easier because the front is so bity.
As my tires aged (7! days; Experimenting how they do over time) I had to dial out rear diff to keep the *** under the car. When I got the car and looked at the wing, I assumed the front would have trouble keeping up with the rear, but its reversed.
I had to slow down initial turn in because the front is so much pointier.
Tires look like they have never been on track so nicely and evenly worn, 180 threadwear does that I guess, but plenty of grip. But now a few seconds slower then new.
I see nothing wrong, but something is not right.
Yes, at Sebring crazy hot, its amazing how cool it stays with just the one (Big ***) radiator / airflow.
AC on all day.
AC on all day.
Go to CUP2 R. Go back to 0 for bump and rebound. Re-try.
Also where was the understeer coming in e.g. corner entry phase or corner exit phase.
What does your corner entry friction circle look like, is it scalloped in or "round" - download and plot your lat g (x axis) linear g (y axis)
I found the 992 RS does under steer on post apex corner exit when pushed.
Adjust one variable at a time, then re-try.
