Nurburgring 3RS settings?
Hi there -- has anyone run their 3RS on Cup 2 Rs at the Nurburging yet? If you have I'd like to know what suspension/diff settings you found the most effective.
Thanks, -hyp
Thanks, -hyp
Jorg Borgmeister used everything on 0, during the record lap.
Now that being said, it depends on your driving stlye, grip level,etc
I like to use a bit of negative compression
Front -2
Rear 0
Rebound a bit mode in the rear, maybe
Front +1
Rear +3
Diff is fine 0,0 but of course if you feel the grip is there, can go a bit more agresssive.
Front -2
Rear 0
Front +1
Rear +3
Cool, thanks gents. 0 is the easiest setting!
Apparently Patrick Long drove the car before the official Car and Driver "Lightning Lap" at VIR and and if I recall correctly they had comp/reb at +4 which surprised me. But with all the bumps around the Ring I can see why 0 is a way more conservative...
-hyp
-hyp
I assume you're talking about the Nordschleife, but you may want to clarify Nordschleife vs. Nurburgring GP circuit.. If "0" is set for the Nordschleife, then the GP track settings would probably be different.
