992 GT3 and GT2RS Forum 2019-Current
992 GT3 pop and vibration in the steerinig wheel when driving over a speed bum
Old 08-15-2024 | 02:53 PM
jforst's Avatar
jforst
5th Gear
Default 992 GT3 pop and vibration in the steerinig wheel when driving over a speed bum
Anyone has any idea what this sound could be? The "pop" along with a slight vibration in the steering wheel only happens when turning while driving over a speed bump, or any other kind of incline or decline.
I can more or less replicate this pop 90% of the time.
Old 08-16-2024 | 10:05 AM
abiazis's Avatar
abiazis
Ackermann effect…..normal
Old 08-16-2024 | 10:21 AM
jforst's Avatar
jforst
5th Gear
It's definitely not Ackermann, and absolutely not normal.
I hear a loud pop/clunk sound, sometimes feel a slight nudge in my steering wheel. It started happening only recently...
Old 08-16-2024 | 11:36 AM
Matt(inMA)'s Avatar
Matt(inMA)
Not in MA anymore
Not sure where you live. Has it gotten colder? When my 997 did this I also felt it in the steering wheel (because they are connected to the wheels). It also happens with my new Vantage on cold(er) days...
Old 08-16-2024 | 12:48 PM
abiazis's Avatar
abiazis
Take the car in to an expert or your dealer under warranty to diagnose.......as its tough to do so online....
Old 08-16-2024 | 01:15 PM
4carl's Avatar
4carl
Check the front swaybar end links?
Old 08-18-2024 | 08:33 PM
1988's Avatar
1988
this was the first symptom I had, dealer had no Idea of what was happening.
I put more km on my GT3 and finally the pop changed to a claclk-clack sound, it was a broken steering box.
hope you have good luck finding the issue
Old 08-19-2024 | 02:14 PM
Orca911's Avatar
Orca911
I have this too. its been getting progressively worse. I noticed yesterday I can make it clonk by going on and off throttle. I happened to shoot a video to show that. And it does it over slight bumps.
Video here >>>>>
@1988 did you fix this? dealer?
Old 08-19-2024 | 08:16 PM
1988's Avatar
1988
Video here >>>>> annoying pop
that's the same sound I had at first.
It will get worse.
Dealer fixed this when sound was located ( took 2 visits to dealer to find it ).
hope you can fix it ASAP.
Old 08-26-2024 | 02:20 PM
Orca911's Avatar
Orca911
It will get worse.
It is getting worse. Can you give some more info on what exactly it was? Will help me streamline dealer troubleshooting.
thanks.
Old 08-26-2024 | 03:45 PM
jforst's Avatar
jforst
5th Gear
I did, replaced both of them and while they did have some free play, replacing them didn't fix the issue.
Old 08-26-2024 | 04:10 PM
npalacio's Avatar
npalacio
Hard to tell from your video but mine does sometime like this when pulling into my driveway at times, which has a pretty steep angle to it. Never does it otherwise and have stopped worrying about it, seems to do it less as I have put more miles on it now that I think about it.
Old 08-26-2024 | 04:17 PM
sunghyun7's Avatar
sunghyun7
when I did steering wheel change, i noticed the main factory bolt that holds on the wheel to the shaft was pinky finger tight. that isn't exaggeration. does the wheel make the sound when you pull and push on the wheel? if so, that bolt may be coming loose. should be simple to see. just pop the airbags out which takes couple minutes and check the bolt.
Quick Reply: 992 GT3 pop and vibration in the steerinig wheel when driving over a speed bum
