Nankang CRS-V2 on 992 GT3
#31
This ^^^ Testing is key and 200 TW tires can have a +1 sec difference per mile between various brands. This without considering heat and wet tolerance. There is no one tire does it all so you have to pick what works best for your usage. In my case it's RE-71RS for cold weather and wet track conditions and CR-S V2 for hot weather. This is GT4 sizing so your options may vary depending on sizing.
Peter
Peter
#32
Would imagine the individual has switched over to a set of 19 inch wheels , as I know of 3 GT4s and a GT4RS that has gone with that inch smaller wheel to get more tire choices -- pretty common with many Trackrats!
#33
#34
Understand. But that combo also changes the rake and will affect the aero requiring additional changes for optimal. Not only that but a 255 on a 8.5 wheel, not sure how much additional grip that much pinching will do.
GrantG (12-25-2023)
#35
Have CRS v2 on my 997 GT3RS and GT4RS, they are much faster than Cup 2 and similar grip level to the RE71RS, just slightly slower than the Cup 2 R but last a lot longer. I was about 2 seconds faster changing to CRS from Cup 2 on a 2.5 mile track. They ride just a little stiffer but miles better than AR1.
These new performance tires RE71RS, Supercar 3R and CRS are really leaps above cup 2 now.
The following 4 users liked this post by bobodrink:
#36
They also do make a 245/35/20 if you're so concerned with rake. I think those tire heights would create a negligible impact on rake. Understand the GT4 already doesn't make much downforce and changing the rake so slightly wouldn't impact downforce production a noticeable amount. We're talking differences of 1-5 pounds of downforce, if that, with how small the changes in height would be. It certainly wouldn't affect handling either. Understand the GT4 is not a slow car. But it's also definitely not a race car where changes of less than an inch of height will make a noticeable change to the downforce or handling balance. The car doesn't even make much downforce at track speeds. Not to say the aero elements on that car are unimportant but they are not as sensitive as you are making them out to be. Also, the Nankangs already runner wider and taller. I wouldn't be surprised if the 245/35/20 Nankang is taller and wider than a Cup 2 of the same size. The same would go for the rears.
WillyDaP (12-26-2023)
#38
Peter
Peter
#39
I would go with 245/35/20 & 285/30/20
If you look at the track width specs on the 285's, they pretty much match the OEM 295's. Also, the height of the 285's are only .2 inch shorter. 26.8 instead of 27
You also gain a full 1" of track width on the fronts with the stock sizing.
Sounds like a winning combo to me. You get to dial out some understeer, while gaining grip on both axles.
If the SC3's get delayed past Feb. (which is their current in stock date), I will probably give that combo a try instead of going back to the AD09's
#40
Solid advice from Peter the Farmer , he is just planting the seed to make sure all his friends check out the tire options for ...................19 inch wheels. Gotta agree, ifen du bist ein Track Ratte, 20s suck for options.
#42
For those that have used CR-S v2 on the track, what cold pressures are you using ?
LiveNupe (03-18-2024)
#43
