992 GT3 and GT2RS Forum 2019-Current
BEFORE you call Roadside Assistance (dead battery)
Old 11-18-2023 | 11:45 AM
200mph's Avatar
200mph
Lightbulb BEFORE you call Roadside Assistance (dead battery)
To open the frunk to access a dead battery... DON'T USE A "JUMP PACK" !
My 992 GT3's Li-Ion battery died, but none of my NOCO jump packs or "smart" charger would open the frunk when connected to the red dongle in the driver footwell fuse box.
Why? Those devices are microprocessor controlled, and need to sense a current draw to work.
Jumping the red dongle from a regular 12V battery (another car with jumper cables) worked just fine! RED to the dongle, BLACK to the door hinge. See YouTube videos for "992 Dead Bettery"
You CAN'T open the Frunk using the Switch in the Door Sill
The red dongle in the fuse box does NOT connect to the car's electrical system... it ONLY connects to the frunk release receiver and latch.
You must use your key fob .to open it, because the door sill frunk switch gets no power from the dongle.
Next... my "smart" Li-Ion charger would not revive Porsche's battery. Microprocessor controls again. It connected and charged for a brief period, then shut down. So...
I jump started the car from our Cayenne with jumper cables. RED to the 992 battery's + post, BLACK to the indicated chassis ground (NOT directly to the battery).
Then I took the car on a spirited drive, 20 miles or so, keeping the revs up. The voltmeter went up to 14.3, and finally settled at 13.5.
I pulled into the garage, and opened the frunk before I shut the car off.
The next morning, I hooked up the charger and it soon settled into its "maintainer" role... battery fully charged.
These things I learned in a frustrating three hours or so... sometimes our tools are too "smart" for their own good!
The following 2 users liked this post by 200mph:
GT3 Mike (11-18-2023), M5150 (11-18-2023)
Old 11-18-2023 | 12:17 PM
GT3 Mike's Avatar
GT3 Mike
Those Li-ion jumper packs only work if there is enough juice in the battery to trigger the jumper to work. I got rid of my NOCO and went back to a lead acid jumper box. Works a million times better.
Old 11-18-2023 | 12:45 PM
4carl's Avatar
4carl
I have two jump packs and they both have the ability to put out 12 V.
I would assume that should work. I’m not talking about jumping the car just getting the trunk open.
I’ve checked with a voltmeter and you can get voltage out same as you would. A battery.
I thought it would work?
The Gt3 has been OK but I just picked up a GTS with an AGM battery.
My last S had with an AGM crapped out on me.
We’ll see ,
Old 11-18-2023 | 04:02 PM
subshooter's Avatar
subshooter
Do you know why your Lithium Battery died?
Old 11-18-2023 | 04:49 PM
MaxLTV's Avatar
MaxLTV
It's dead simple - you need to supply 12V. Any supply will work. Many NOCOs have 12V supply mode (all current ones do, even the $40 one), which is different from battery charging. Sometimes you need to leave it connected for a few minutes before trying to open but it does open. Same with starting - jumpstart-capable supplies are the best because they would start the car right away, and then you can charge by driving or connecting any charger, and it will keep going. Without a jump-starter, it's also possible with most chargers, just takes more care. It's best to have a jumpstart-capable charger or a charger with 12V amp boost mode (e.g., NOCO G15000 did the job every time for me) - it takes 2 minutes to boost a car with either, but with jumpstarter, it's just dead-simple.
5MDNY9 (11-20-2023)
Old 11-18-2023 | 05:05 PM
MaxLTV's Avatar
MaxLTV
Yes, you are good. For opening, anything that can supply 12V will do the job. Smart chargers just shut off when they do not see the battery on the other end, so that's why some fail, but most chargers have "force mode" or "12V supply mode" that will work - just need to remember to turn it on. For boosting the car, you need more amps than most normal 12V supplies would give, and some dumber smart chargers may not start charging a dead lithium battery because they do not see the battery when it's in protection mode. So you need a charger that can charge from zero volts or booster. But any jumpstarter/booster would do it - I got a gas station store piece of crap booster to work every time. Jumper cables from another battery work too, for both opening and starting.
Old 11-18-2023 | 07:40 PM
4carl's Avatar
4carl
Old 11-18-2023 | 08:21 PM
daveo4porsche's Avatar
daveo4porsche
my NOCO's have worked for:
Audi eTron - start the vehicle
2020 Taycan (3x times) - open frunk & start the vehicle
2022 911 TurboS Cab - open frunk & start the vehicle
2018 911 GT3 (2x times) - open frunk & start the vehicle
I had to press the "boost" button…
I think YMMV in this situation - but I've had no problems using NOCO's to open the frunk and then using the same NOCO to actually start the vehicle.
not sure what the problem was in this case, but they do not universally fail - I agree a known good 12V battery should also work and less complex than a NOCO - but I don't mind hauling a NOCO with me in the car (for dead battery if I'm ever away from home) - not sure I want to haul a dedicated 12V battery with me in my vehicles.
YMMV
Old 11-19-2023 | 05:22 PM
signes's Avatar
signes
What's the consensus on the best trickle charger?
Quick Reply: BEFORE you call Roadside Assistance (dead battery)
