RS Door Pull Conversion
Check the end of our DIY video below
https://youtu.be/dEixFKzfaDA?si=BBl5EY1LfmtB_OJF
below is a more recent DIY we published
https://youtu.be/kgI2WtKxw8U?si=wabVN1PfdNU8rMhM
Thank you!!!
I have received several requests for the necessary part numbers. The numbers are below for anyone who is interested but I believe it is less expensive to order the complete kit from Suncoast.
9GT-837-019-C-N13 - Door pull assembly w/Red Straps
9GT-837-020-C-N13 - Door pull assembly w/Red Straps
9GT-868-538-C-5Q0 - Door panel trim assembly
9GT-868-537-C-5Q0 - Door panel trim assembly
N-911-768-01 - Screws (Need 6)
There was no instructions included but it is very intuitive. I followed a Youtube video on the door panel removal and there is no modifications necessary. The lever release can be reinstalled as necessary.
recognizing this is a old post… BUT - I finally got around to installing the RA door pulls I got from Suncoast (hadn’t seen GT3 yet when I ordered) and halfway through realize they didn’t include the 6 screws you need to install the interior plate over the mechanism, different than the permanently affixed plate on the standard door pull. So just hoping to verify that the screws you referenced above are the part number for those that hold the interior RS door pull plate on. 95% sure but figured I’d ask. Going to be driving with some taped on plates til I get them, don’t feel like uninstalling everything until the screws are located. Thanks!
Thanks, that is helpful as I wasn’t completely sure if they did. I shall contact them but TBH, my impatience and hatred of partially complete was making me want to stop by dealer and see if they have some screws to just buy, they seem quite cheap if they are the part number referenced above…
There is a reason why Porsche decided against adding the strap pulls to the Weissach package on the 992.2 GT3....the door actuators kept failing when tested for durability.
