GT3RS suspension settings- Track to Normal modes
When you adjust the compression and damping in track mode, what happens when you switch back to sport or normal mode? Are the adjustments maintained or does it go back to a "factory" setting?
Not sure if this answers your question but if you change suspension settings in track mode and then go to normal or sport mode you will have the factory settings for those modes. When you select track mode again it will have saved any changes you made prior in track mode.
