992 GT3 and GT2RS Forum 2019-Current
Alekshop Installs BBi Autosport StreetCup Roll Bar in Black Porsche 992 GT3
Old 04-20-2023 | 09:52 PM
BBiAutosport's Avatar
BBiAutosport
Basic Sponsor
Default Alekshop Installs BBi Autosport StreetCup Roll Bar in Black Porsche 992 GT3
Attachment 1335528
Alekshop Installs BBi Autosport StreetCup Roll Bar in Black Porsche 992 GT3 for Added Safety on the Track
Featured Dealer InstallIf you're a Porsche 992 GT3 or GT3 RS owner who wants to hit the track in style and with confidence, we have something for you. Alekshop, our premier dealer in Fremont, California, recently installed our BBi Autosport StreetCup Roll Bar in one of their client's Porsche 992 GT3, and we are excited to share it with the Rennlist community!
The roll bar in this car was finished in a subtle satin black powder coat and optioned with gussets for added strength. The Schroth Racing harnesses are red, which adds a pop of color and matches the stitching.
The BBi Autosport StreetCup Roll Bar is made from high-strength seamless steel tubing that has been engineered to offer an exceptional strength-to-weight ratio. With "X" braces on the front and rear sections, the roll bar provides secure mounting locations for the shoulder straps of 6-point racing harnesses, ensuring your safety during high-G maneuvers. It is designed to mount to the frame structure behind the driver and rear shock towers for maximum protection.
The roll bar is designed for a perfect fit and easy installation, using laser scanning of the vehicle's interior and CAD design. It comes with laser-cut mounting plates and inner diameter tube clamps that are CNC turned and milled for a precise fit. The roll bar allows full-seat travel and can be used with stock seats or any aftermarket seats on the market. It is also compatible with wrap-around style harnesses.
It's important to note that installing 6-point harnesses requires aftermarket racing seats or the factory Porsche Lightweight Full Bucket Seats. The BBi Autosport Sub-Belt Bracket and Harness Install Kit are also required when installing 6-point harnesses on the factory Porsche Lightweight Full Bucket Seats. The Sub-Belt Bracket bolts to the bottom of the seat to provide a mounting location for the anti-submarine belts, also known as the crotch belts. The Harness Install Kit includes extended bolts to accommodate the OEM seat belts and racing harnesses at the factory mounting locations on the seat.
The BBi Autosport StreetCup Roll Bar is designed for a bolt-in installation that requires no drilling and minimal carpet trimming. We take great care in packaging the roll bar for delivery, using foam-in-place expanding foam packaging to ensure safe delivery worldwide without any damage to the finish.
This roll bar is made in the USA and is the perfect solution for any Porsche 992 GT3/ GT3 RS owner looking to hit the track with confidence and style. If you have any questions or want to place an order, please contact us at 714-843-0200 or email us at sales@bbiautosport.com. You can also order the BBi Autosport StreetCup Roll Bar online at www.bbiautosport.com/collections/992-gt3.
BBi Autosport Porsche 992 GT3 / RS StreetCup Roll Bar
Features:
  • 1.75” x 0.095”, 1.5” x 0.083” high strength seamless tubing-strength excellent strength to weight ratio
  • TIG welded and utilized “X” braces on front and rear sections for superior strength and rigidity
  • Mounts to frame structure (utilizing factory bolts) to provide the strongest mounting points and maximum protection. Mounts to shock towers in the rear.
  • Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise fit
  • Designed to work with stock seats or any aftermarket seats on the market
  • Allows full-seat travel to accommodate taller drivers
  • Can be used with stock seat belts or 6-point harnesses for track use
  • Designed to work with wrap-around style harnesses
  • OEM fit & finish. The main hoop contours the entire arch of the roof with an even 3/16-inch gap
  • Can be finished in a satin black powder coat, or we can match many of the OE colors like brake calipers, seat belts, trim detail, and exterior paint
  • Made in USA
FITMENT:
2020+ 992 GT3 / RS
Product Link ➡️https://bbiautosport.com/collections...ar-992-carrera
BBi Porsche 991 GT3/ GT3RS / Cayman GT4 Sub-Strap Mount
When equipped with optional Sport Bucket seats, this bracket is required to install 6-point race harnesses. This bracket bolts directly to the seat and keeps the harnesses at the proper 10-20° angle regardless of the seat position.
Features
  • Provides mounting location for sub-belts at the proper 10-20° angle regardless of the seat position
  • Precision CNC laser cut and bent from one piece high carbon steel for superior strength
  • Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
  • Attaches to seat assembly using factory mounting points with all hardware included
  • Compatible with Porsche 991 GT3 and 981 Cayman GT4 models equipped with Sport Bucket Seats
  • Made in the USA
Product Link ➡️https://bbiautosport.com/collections...b-belt-bracket
BBi Harness Install Kit
BBi Harness Install Kit included extended bolts to properly accommodate both the OEM seat belts and racing harnesses at the factory mounting locations on the 991 GT3 / 981 GT4 Sport Bucket Seats. This kit features metal sleeves fitted around the bolts so that the belt brackets can pivot freely on the bolt. Sold as a kit per seat.
Product Link ➡️https://bbiautosport.com/collections...at-991-981-gt3
About Alekshop
Attachment 1335469
Shop Address:
4390 Technology Drive
Fremont, CA 94538
Phone Number:
(925) 609-4559
Links:
www.alekshop.com
www.facebook.com/alekshop/
www.instagram.com/alekshop_com
- Jerry@BBiAutosport.com
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Quick Reply: Alekshop Installs BBi Autosport StreetCup Roll Bar in Black Porsche 992 GT3
