Car stalling at idle in neutral
I’m guessing here but it’s most likely due to how the 02 sensors were reinstalled. They may have reversed the 2 on 1 side or both sides. I watched this video below and installed my full dundon system myself on a creeper over 3 days. 2.5 hours per day so that I wouldn’t overthink or over work myself. Came out perfect.
I really don’t trust anyone working on my cars nowadays. Even dealer. Good luck.
I also have a 992 touring 6MT, mine is stock with just over 300 miles and I have to say it sounds like auto stop/start, if you disable this does the problem go away... sorry if you already said you tried this, just wanted to share that everything you describe is exactly what I experience in my car except my idle is smooth as it is bone stock.
I would remove one after cat o2 sensor, see if there is a part number on it and ask your dealer if that is the correct part for after cat O2. That way you will know which bank is correct and which one isn’t.
jsnadams (01-12-2023)
Wasn’t there someone else reporting an issue and discovered it was an issue with the O2 sensor a gf how the mechanic didn’t install it properly when changing the exhaust. I seem to remember something like that.
As far as the Tecnica goes, I have the order in place but still no allocation. My dealer says that production will run through 2024. Tecnicas are sold out, but apparently those with orders in place will be getting a car, depending on the dealer. Just have to wait it out - and then figure out what I'm going to do as I can't keep both the GT3 and the Tecnica together.
Engro (01-26-2023)
