Front Wishbone Suspension
Mercuriell (09-29-2022)
All that stuff has to do with the ratio in the steering rack and lack of rubber in the suspension. Those things can be changed independently of the double wishbones. Double wishbones on the Carrera could be just as comfy or moreso, but it would resist understeer much better when driving in a spirited way. And tire wear would be better without the need for an aggressive alignment.
Probably never, its much more expensive and complex to manufacture than a strut suspension. Porsche has done a very good job of maximizing the performance of the strut . Look at the 991 GT3RS >4RS. The cost/benefit ratio in the std 911 line doesn't make sense.carl
rodneyr (09-29-2022)
While wishbones are a big benefit on the GT3, that benefit is better control over alignment over the range of motion (dynamic camber/toe), in a plush car there is more suspension movement and so intentional engineering of the camber/toe curve over that range with wishbones is even more beneficial.
The latest miata, which has a way too soft suspension stock, does well with its front double wishbones. https://www.autoblog.com/2020/04/30/...ion-deep-dive/
